Go Back   Badcaps Forums > General Topics > General Capacitor Questions & Issues
Old 01-17-2018, 11:57 AM   #1
jayjr1105
jayjr1105's Avatar
City & State: Lancaster, PA
My Country: United States
Line Voltage: 120VAC 60Hz
I'm a: Hardcore Geek
Default Video card Capacitor question
In the image below, you obviously have the + and - leads. What is the other lead close to the negative? Is it a problem if that lead gets bridged with the negative when re-capping?
https://imgur.com/i5y8AGo
BTW, I assume crap caps?... http://prntscr.com/i1txzi
jayjr1105 is offline   Reply With Quote
Old 01-17-2018, 12:03 PM   #2
Andrew F. Ali
Andrew F. Ali's Avatar
City & State: Point Fortin
My Country: Trinidad & Tobago
Line Voltage: 125VAC 60Hz
Default Re: Video card Capacitor question
I have never seen a cap with 3 leads. If you post a pic of the underside of the board it would help in answering your question.
Andrew F. Ali is offline   Reply With Quote
Old 01-17-2018, 12:04 PM   #3
jayjr1105
jayjr1105's Avatar
I'm not saying the cap has 3 leads. I'm wondering what that pad close to the negative is for? It appears to be common on older video cards to have that pad super close to the negative lead.
Old 01-17-2018, 12:56 PM   #4
Per Hansson
Per Hansson's Avatar
City & State: ----
My Country: Sweden
Line Voltage: 230v 50Hz
It's to accommodate caps with different lead spacing, 5mm or 7.5mm in this case would be my guess.
Old 01-17-2018, 01:03 PM   #5
jayjr1105
jayjr1105's Avatar
Are you guessing at the lead spacing differences or the accommodation part?
Old 01-18-2018, 08:24 AM   #6
Andrew F. Ali
Originally Posted by per hansson View Post
it's to accommodate caps with different lead spacing, 5mm or 7.5mm in this case would be my guess.
+10000
Old 01-18-2018, 03:23 PM   #7
jayjr1105
jayjr1105's Avatar
I did confirm this with a continuity test. I guess if they bridge during a re-cap, it's no big deal.
