Badcaps.net Forum
Go Back   Badcaps Forums > Welcome to the Badcaps.net Tech Forum! > Frequently Asked Questions (No Posting)
Thread Tools Display Modes
Old 03-15-2013, 07:14 PM   #1
tom66
tom66's Avatar
City & State: Leeds
My Country: UK
Line Voltage: 230Vac 50Hz
I'm a: Professional Tech
Default Understanding TV Power LEDs
It seems a lot of people can be confused by the power LED on the TV they're working on. If you've never seen a particular model, the LED may be confusing if it doesn't behave as one might expect. A list of typical power LED states for a variety of brands are included in this post.
Atec (Only one model for sure)
Power LED is RED in standby. Powering up the TV makes the LED go ORANGE, then GREEN. If no input present or the signal isn't present, may go orange again. No known blink codes.
Hyundai (Only one model for sure)
Power LED is RED in standby. Powering up the TV makes the LED blink GREEN, then go solid green.
LG (Older models)
Power LED is RED in standby, then WHITE or GREEN when powered on. May flash when first powering on. Only blink code is continuous flashing on some models, which indicates a power on fault (generally non-specific though typically the PSU.)
LG (Newer models)
Power LED is RED in standby, and pulsates red when powering up. Once powered up, the LED goes out or turns BLUE or WHITE. No known blink codes.
Panasonic (European, possibly other regions)
Power LED is RED in standby. Immediately detected errors detected lead to a blink code (see service manual.) When powered on, the LED will then blink GREEN. If an error is detected during the power on phase, an error code will then be thrown (LED will blink red.) If the self-test succeeds, the LED will light solid green and the TV should be fully powered up. If a fault occurs during operation, a blink code may be thrown in the same way as before.
Panasonic (US)
Power LED is RED in standby. Immediately detected errors detected lead to a blink code (see service manual.) When powered on, the LED will then blink red rapidly. If an error is detected during the power on phase, an error code will then be thrown (LED will blink red.) If the self-test succeeds, the LED will light solid red and the TV should be fully powered up. If a fault occurs during operation, a blink code may be thrown in the same way as before.
Philips (Some models)
Power LED is RED in standby. When turned on it may go BLUE or GREEN. If an error occurs, a blink code may be used (this may be green, blue or red.)
Samsung
Standby WHITE, RED or BLUE. When turned on, usually blinks. When fully powered up the LED will extinguish. No known blink codes.
Sharp (non-Vestel) (some models)
Power LED is RED in standby. When turned on, LED turns green. If an error occurs, the LED will go red and will flash along with the OPC LED. The combined error code greatly narrows down the issue: an error of 2-5, for example, indicates a main board 5V failure. (One can wish for other manufacturers to implement this... but they haven't.)
Sony
Power LED is RED in standby. When turned on, may or may not blink. LED turns GREEN when turned on. Blink codes on some models (refer to service manual.)
Toshiba (non-Vestel)
Power LED is RED in standby. Powering on may result in a GREEN power LED. If an error occurs, the green will go off. No known blink codes.
Vestel
LED is typically lit in standby, and may vary in colour. This varies with each model. When powered on, if a self test fails, the LED will blink continuously until the unit is unplugged. LED is typically dark when powered on. No known blink codes.
Vizio
Glowing logo usually ORANGE in standby. When turned on goes WHITE. An error after turning white will typically lead to the LED staying lit white. No known blink codes.
__________________
Free service manuals: http://www.toms-service-manuals.com/ -- 72 LED/LCD TVs, 5 monitors, 28 plasma TVs, and 2 AVR 6.1 amplifiers fixed! -- I repair Pioneer 9G Plasma Main Boards & KRP-M01 Media Receivers (PM me for info)
2 Pioneer KURO 9G, 12 Panasonic LCD/Plasma, 1 Sony LCD, 1 NEC Plasma, 2 Yamaha HTS, 5 Sharp LCDs, 5 Toshiba LCDs, 7 Philips Plasma/LCD, 1 Hitachi Plasma, 11 LG LCD/Plasma, 18 Samsung LED/LCD/Plasma, 1 Thomson Plasma, 1 Atec LCD, 1 Hanspree LCD, 1 Xerox LCD, 1 Harwa LCD, 2 Proview LCD, 2 Hyundai LCD, 1 "Onn" LCD, 1 Grundig LCD, 1 Dell LCD, 1 iiyama LCD, 1 Acer LED, 1 Logik LCD, 1 Baird (China) LCD, 6 Bush LCDs, 22 Vestel LCDs (Best->Worst)
tom66 is offline   Reply With Quote
Old 03-17-2013, 11:22 PM   #2
cheapie
null
City & State: Walcott, IA
My Country: USA
Line Voltage: 124VAC 59Hz
I'm a: Hobbyist Tech
Default Re: Understanding TV Power LEDs
Orion (Only one model for sure)
Power LED is solid RED for off, blinking RED for computer-initiated standby (VGA input). When turned on, power LED turns OFF, and display shows "Please Wait" until startup is complete.
cheapie is offline   Reply With Quote
Old 03-19-2013, 03:40 AM   #3
Radio Fox
Radio Fox's Avatar
City & State: East London
My Country: UK
Line Voltage: 230VAC 50Hz
Quote:
Originally Posted by tom66 View Post
...Hyundai (Only one model for sure)
Power LED is RED in standby. Powering up the TV makes the LED blink GREEN, then go solid green...
Now you've confused me.
__________________
________________________________________________
Invisible airwaves crackle with life
Bright antennae bristle with the energy
Radio Fox is offline   Reply With Quote
Old 03-19-2013, 11:55 AM   #4
ratdude747
Black Sheep
ratdude747's Avatar
City & State: Madison, IN
My Country: USA
Line Voltage: 120VAC 60Hz
Quote:
We need blinking text. IIRC there is some sort of HTML that does that. Not sure if there is forum code equivlents though.
__________________
(Insert witty quote here)
ratdude747 is offline   Reply With Quote
Old 03-21-2013, 07:57 PM   #5
Topcat
The Boss Stooge
Topcat's Avatar
City & State: Salem, MO
My Country: United States
His reference is to Hyundai, that should explain it all!
__________________
<--- Badcaps.net Founder & Owner
Badcaps.net Services:
Premade Capacitor Kits
Badcaps.net Capacitor Master List
Motherboard Repair Services
If you've come here in search of replacement capacitors or repair services, please use the links above.
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats
Topcat is offline   Reply With Quote
Old 03-22-2013, 07:04 AM   #6
tom66
tom66's Avatar
City & State: Leeds
My Country: UK
Lol, yeah. Don't know about their cars but their TVs are sure rubbish. Picked it up (32" LCD) for 10 on eBay, needed a new diode. Also replaced 8 crappy capacitors. Has three dead pixels in a row, solid green ("C" grade panel.) Draws something like 15W in standby with just the LED lit. Put it in the kitchen, not worth selling.
Old 03-22-2013, 09:38 AM   #7
Radio Fox
Radio Fox's Avatar
My Country: UK
This thread reminds me of a Brain Training game I played on the Nintendo DS where you had to say the colour of the word, not the colour that the word spelled out. It measured the "Stroop Effect".
http://faculty.washington.edu/chudler/words.html
Old 03-22-2013, 09:38 AM   #8
lti
lti's Avatar
City & State: Windsor, Colorado
The word "green" is colored yellow.
lti is offline   Reply With Quote
Old 03-31-2013, 12:16 PM   #9
tom66
tom66's Avatar
City & State: Leeds
My Country: UK
That is an error I made, if a moderator wishes to correct it I have no objection.
Old 03-31-2013, 02:55 PM   #10
janet301
City & State: Pagadian City
My Country: Philippines
I'm a: Knowledge Seeker
Quote:
yeah right..,its colored yellow...
janet301 is offline   Reply With Quote
Old 04-02-2013, 01:13 PM   #11
ratdude747
Black Sheep
ratdude747's Avatar
My Country: USA
Fixed it.
No sweat. We all mess up from time to time...
Old 10-07-2016, 03:00 AM   #12
JacobKLl
City & State: Arlington
Oh, my new LG says you thanks! Full information
JacobKLl is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
