List of pin compatible Laptop ICs
This is a sticky topic.
    Re: List of pin compatible Laptop ICs
    BQ24753A can be replaced with BQ24751A working and charging on a sony vaio VPCeb1j1e
      can i replace BQ24728 with BQ24727 ? I dont have exact model
        they are sliglty diferent in some pins , alltough i could only look to the pins , and not to the internal functions ,
          im looking to replace bq24728.. i see highpulse u have success with bq24725A but what boards has these?
            i used in a mbx-223 , well but if you look to pinout is fully compatible , alltough there LDO current is bit diferent , but on this machine its working and charging perfectly 2 days now running all good
              well mbx , 281 , BQ735F a charger ic , problem bttery not detected , tryed with a BQ725A still working , but still dont know if will charge battery or not , but in any case , 735F and 725A pinout is the same
                ITE IT8570E possible to swap to IT8572E on does two equipments i swaped and working K54JR and k54ly
                  Hi!
                  any equivalent of isl95835hrtz-t?
                  Thank you!
                    to support the idea and for the best forum and members : (this is my full list of compatibility)
                    · G86-631-A2 = G86-621 = G86-620 = G86-630 = G86-603 = G86-920
                    · G86-920-A2 = G86-921-A2
                    · GF-GO7200-N-A3 = GF-GO7300T-N-A3
                    · GF-GO7300-N-A3 = GF-GO7300T-N-A3
                    · GF-GO7400-N-A3 = GF-GO7400T-N-A3
                    · QD-NVS-110M-N-A3 = QD-NVS-110MT-N-A3
                    · G86-740-A2 = G86-741-A2
                    · GM45 = GL40
                    · HM55 = HM57
                    · HM65 = HM67
                    · 216-8018 = 216-8020
                    · 216-4026 > 216-4024 > 216-4022
                    · 216PABGA13F = 216PACGA14F
                    · 216PBCGA15FG = 216PBCGA15F
                    · 216QMAKA14FG = 216RMAKA14FG
                    · 216RMAKA14FG = 216QMAKA14FG
                    · 216MJBKA15FG = 216MJBKA11FG216PNAKA13FG = 216PMAKA12FG
                    · 216PQAKA12FG = 216PQAKA13FG
                    · 216PQAKA13FG = 216PQAKA12FG
                    · 216PMAKA13FG = 216PMAKA12FG
                    · 216PLAKB26FG = 216PLAKB24FG
                    · 216CPIAKA13FL = 216CPIAKA13F
                    · 216BS2BFA22H = 216BS2BFB23H
                    · 216DCP4ALA12FG = 216ECO4ALA13FG
                    · 216MSA4ALA12FG = 216MCA4ALA12FG
                    · 216MPA4AKA21HK = 216MPA4AKA22HK
                    · 216-0674024 = 216-0674026
                    · 216-0707007 = 216-0707001
                    · 216-0707001 = 216-0707011
                    · 216-0707005 = 216-0707009
                    · 216-0707009 = 216-0707005
                    · 216-0707011 = 216-0707001218S4PASA14G = 218S4PASA13G
                    · 218S4EASA31HK = 218S4EASA32HK
                    · 215NSA4ALA12FG = 216MSA4ALA12FG
                    · 216-0772003 = 216-0772000
                    · KB926QF = C0, C1= D2,D3
                    · IT8500E = IT8502E = IT8512E
                    · WPCE775 = WPC773
                    · WPC8763 = WPC8769
                    · SMSC KBC1098 = SMSC MEC1308
                    · RT8205A = TPS51125
                    · ISL6236 = RT8206A = PM6686
                    · ISL6268 = APW7138
                    · TPS51117 = RT8209B
                    · TPS51116 = RT8207ISL6227 = APW7108
                    · TPS51125 = RT8205B = UP6182
                    · TPS51123 = RT8223M
                    · P2805MF = G5933
                    · SN608090 = ISL6237 = 51427 RT8206B
                    · ISL6237 = MAX17020 = MAX8778 = TPS51427 = RT8206B
                    · PM6686 = TPS17020
                    · UP1585QQAG (EM = EC) = TPS51123A = RT8223P ( EQ=XX)
                    · MAX8734A = RT8203
                    · MAX 8724 = MAX1908
                    · ISL88731= BQ24745
                    · ISL 6266 = ISL 6262
                    · ISL 62883 = ISL 62882
                    · ALC883 = ALC660
                    · RT8223 = 51123
                    · (DH=CH)= (DH=CA)= RT8207
                    · W8769 = W8763
                    · SN608090 =ISL6237 = 51427 = RT8206B
                    · IT8500E = IT8502 = IT8512
                    · ISL6266 = ISL6262
                    · ISL62883 = ISL628823
                    · RT8223 = RT8205
                    · ITE8502E = ITE8512E
                    · ITE8512EKXS= ITE8512EKXO
                    · PM6686 = TPS17020
                    · UP1585QQAG (EM EC) = TPS51123A = RT8223P(EQ=)
                    · ISL88731=BQ24745
                    · RT8206B = ISL 62373
                    · MAX8734A = RT82032
                    · J493 (G966-93) = RT9018B (DELL VASTRO 1015)
                    · KB926QF D3 = KB926QF CO
                    · KB3926QF D3= KB3926QF
                    · RT8205(A) = TPS51125
                    · (EF = DE 41J) = RT8207LGQW
                    · (CJ=CL 40W) = TPS51125
                    · KB3310QF-A0 = KB3310QF-B0 Asus All-in-One PC ET1602C
                    · KB3310QF-C1 = KB3310QF-B0 Asus EeePC 900
                    · KB3926QF-A1 = KB3926QF-A2 Quanta AT3
                    · KB3926QF-C0 = KB926QF-D3 HP DV5
                    · KB3926QF-C0 = KB3926QF-D2 Quanta OP6, QT6
                    · KB3930QF-A2 = KB930QF-A1 Quanta R23
                    · KB926QF-B1 = KB926QF-C0 Compal LA-3551P
                    · KB926QF-B1 = KB926QF-D3 Compal LA-6552P
                    · KB926QF-D3 = KB926QF-C0 Lenovo G550 - Compal LA-5082P
                    · KB926QF-E0 = KB926QF-C0 Compal LA-6061P
                    · KB926QF-E0 = KB926QF-D3 Compal LA-6311P, Lenovo G555 (LA-5972P)
                    · KB926QF= KB926QF-D2 Compal LA-6421P, LA-6221P
                    · WPCE773 = WPCE775
                    · WPC8763LDG = WPC8769LDG WistronBiwa, Aspire 5920G - Quanta ZD1
                    · WPC8769LA0DG = WPC8769LDG Alienware M15x - Quanta MX3
                    · NPCE781LA0DX = NPCE781BA0DX
                    · NPCE781LA0DX = NPCE783LA0DX Quanta ZQ1
                    · NPCE795GA0DX = NPCE795LA0DX Quanta ZYG
                    · IT8500E = IT8502E Asus K50IJ
                    · IT8502E = IT8500E Asus K40AB, K40C, K50C, K50AB
                    · IT8502E = IT8512E Asus K50IJ
                    · IT8512E = IT8500E Acer 6920
                    · IT8511TE-BXS = IT8510TE-GXA Asus X51R/RL
                    · MEC1300-NU = MEC1308-NU Samsung R530 (BREMEN-L3, 1.0,BREMEN-L4, r1.4), Samsung R519 (BONN-L)
                    · TPS 51125A = RT8205BGQW =(CK=CD C47)
                    · RT8209A = FH=CG CU1
                    · RT8204C = H6=CH JOX
                    · RT8205 = TPS51125
                    · SN10504 =SN0608098 RHBR
                    _________________________________________________________________________________________________________________________________________________________________
                    ck=cd (check the two first letters "ck")
                    EL= -RT8015A
                    DZ= - rt8113
                    CZ= - RT8561AGQW
                    D9= -rt9716AGQW
                    C7= -RT9293-20
                    DJ= - RT8202AGQW
                    DJ- -RT8204PQW
                    DK- - RT8204PQW WQFN3*3-16
                    JL= - RT8204AGQW WQFN3*3-16
                    FR= - RT8204BGQW WQFN3*3-16
                    H6= - RT8204GQW WQFN3*3-16
                    CJ= - RT8205AGQW
                    CK= - RT8205BGQW
                    CL= - RT8205CGQW
                    CB= - RT8205DGQW
                    DT= - RT8205EGQW
                    EM= - RT8205LGQW = RT8205AGQW
                    EN= - RT8205MGQW = RT8205CGQW
                    CP= - RT8207GQW
                    DH= - RT8207AGQW
                    EF= - RT8207LGQW
                    J7= - RT8207MGQW
                    DS= - RT8223BGQW
                    EP= - RT8223LGQW
                    EQ= - RT8223MGQW
                    FF= - RT8208AGQW
                    FG= - RT8208BGQW
                    H8= - RT8208DGQW
                    30= - RT8208EGQW
                    31= - RT8208FGQW
                    FH= - RT8209AGQW
                    A0= - RT8209BGQW
                    A3= - RT8209EGQW
                    JX= - RT8209LGQW
                    A8= - RT8209MGQW
                    K0= - RT8209NGQW
                    _Equivalent RT:_
                    ISL6236=RT8206A=PM6686
                    ISL6237=RT8206B
                    ISL6268=APW7138
                    TPS51117=RT8209B
                    TPS51116=RT8207
                    ISL6227=APW7108
                    TPS51125=RT8205B=UP6182
                    TPS51123=RT8223M
                    ISL6251=G5209
                    P2805MF=G5933
                      Thanks for sharing kiraro
                        Kiraro, thanks, it looks very helpfull
                        Have you ever tried to replace this?
                        · HM55 = HM57
                        · HM65 = HM67
                          · GM45 = GL40
                          · HM55 = HM57
                          · HM65 = HM67
                          · WPCE775 = WPC773
                          · WPC8763 = WPC8769
                          · ISL6268 = APW7138
                          · P2805MF = G5933
                          · PM6686 = TPS17020
                          · MAX8734A = RT8203
                          · ISL88731= BQ24745
                          · ALC883 = ALC660
                          · RT8223 = 51123
                          · W8769 = W8763
                          · ISL6266 = ISL6262
                          · RT8223 = RT8205
                          · PM6686 = TPS17020
                          · ISL88731=BQ24745
                          · WPCE773 = WPCE775
                          · RT8205 = TPS51125
                          EL= -RT8015A
                          DZ= - rt8113
                          CZ= - RT8561AGQW
                          D9= -rt9716AGQW
                          C7= -RT9293-20
                          DJ= - RT8202AGQW
                          DJ- -RT8204PQW
                          CJ= - RT8205AGQW
                          CK= - RT8205BGQW
                          CL= - RT8205CGQW
                          CB= - RT8205DGQW
                          DT= - RT8205EGQW
                          CP= - RT8207GQW
                          DH= - RT8207AGQW
                          EF= - RT8207LGQW
                          J7= - RT8207MGQW
                          DS= - RT8223BGQW
                          EP= - RT8223LGQW
                          EQ= - RT8223MGQW
                          FF= - RT8208AGQW
                          FG= - RT8208BGQW
                          H8= - RT8208DGQW
                          30= - RT8208EGQW
                          31= - RT8208FGQW
                          FH= - RT8209AGQW
                          A0= - RT8209BGQW
                          A3= - RT8209EGQW
                          JX= - RT8209LGQW
                          A8= - RT8209MGQW
                          K0= - RT8209NGQW
                          _Equivalent RT:_
                          ISL6237=RT8206B
                          ISL6268=APW7138
                          TPS51117=RT8209B
                          TPS51116=RT8207
                          ISL6227=APW7108
                          TPS51123=RT8223M
                          ISL6251=G5209
                          P2805MF=G5933
                          thanks a lot pal! but still dont have a compatible IC for isl95835.
                            Is there an equivilent for OZ8111LN and OZ8116LN ? (New Micro)
                              SN105042 compatible ic ??
                                Originally posted by age80 View Post
                                there is a solution , put 2 diodes , frmo pin 1 to 8 and pin 2 to 8 , traces must be turned to pin 8 , after that make a jumper between pin 3 and 6 a,d try to turn on machine
                                  Thanks for the info highpulse
                                    I have just try this but is not working, need more components for this IC
                                    https://www.badcaps.net/forum/showthread.php?t=53603
                                      it must be the glass diode , the cathode size goes to pin 8 , so frmo pin 1 to 8 one diode "glass" from pin 2 to 8 another diode "glass " , then with a wire bypass pin 3 to pin 6
                                      (this will WORK ALWAYS if the problem is related with the IC described !!!
                                      perfectly working on some good machines who had this IC damaged fter making this , it was more than enough to fix it .
                                        now therefore , you must chek before making the jumper , after inserting the 2 diodes , insert dc power , and chek pin 3 it cannot be higher than 3.3 volts also chek pin 6 , it must be 3.3 if its not then chek SIO .
                                        then bypass between 3 and 6 !
                                          Thanks Highpulse you have right ITE chip is burned no 3,3v on pin 3-6.
                                          Can i replace IT8502E with IT8500E?
                                          #sorry its on threat 92 compatible 8502&8500#
