Go Back   Badcaps Forums > Motherboards with Bad Capacitors > Major Manufacturers Boards
Old 03-06-2011, 05:51 PM   #1
REMorgan
Default Emachines - Intel D102GGC2 board
Hi Folks,
A friend has passed me a lemon, and I'm undecided whether to ditch it for an exact new board from Ebay , replace the bad caps or a complete recap. The board has mostly Chemicon KZG's and a few small Ruby's. There are 2 bulging caps 6.3v/820uf between the ATX conn. and the ram slots, the only other is a single 6.3v/3300uf near the northbridge. The junk Bestec also has a bad cap on one of the outputs, so it looks like the cause. He bought used so who knows for sure when the caps all went bad. A new PSU is on the way since I will not waste my time with a Bestec. Searching the forums here it seems the KZG's are not reliable. But how so? What makes them unreliable?
If a full recap is recommended, I've used Panasonic FC and Nichicon HM & HE in the past, are they still on the good list?
Here's a list of caps above 680uf :
(1) KZG 3300/6.3 - bulging
(4) KZG 1000/16v
(15)KZG 820/6.3 - 2 bulging
(5) 6Z1 821/2.5 - poly , red lettering ..sorry can't tell brand , these are on the output for the cpu vrm looks like.
BTW the pc will POST although sometimes it wont , so I feel it's fixable.
Your thoughts ?
TIA
REMorgan is offline   Reply With Quote
Old 03-06-2011, 06:10 PM   #2
c_hegge
c_hegge's Avatar
My Country: Australia
Line Voltage: 240V 50Hz
Default Re: Emachines - Intel D102GGC2 board
Should be totally fixable. You can probably leave the polys and rubycons in place, but the Chemi-Con KZGs all have to go. Recapping it should be fairly cheap, even a complete recap.
For the 3300uF caps, use these
For the 1000uF 16v caps, use these
For the 820uF caps, use these.
c_hegge is offline   Reply With Quote
Old 03-06-2011, 07:06 PM   #3
c_hegge
c_hegge's Avatar
Nichicon HM would also work, but don't use HE or panny FC, since the ESR is way too high for use on motherboards
Old 03-06-2011, 10:55 PM   #4
REMorgan
Thx Mate,
Its been a spell since I visited here. I have been using this list for quite some time. Knock on wood , nothing has come back blown up. Thanks for the links to the Ruby's , makes it easy to pick them up when they are being offered by the House. Saved me time, nice indeed.
Cheers from Texas
Old 03-07-2011, 03:03 AM   #5
c_hegge
c_hegge's Avatar
Not all on that list are good for motherboard use. The ones on that list are all low ESR, but what you really want is super low ESR, and the only reliable series which are low enough are Ruby MBZ and MCZ, Nichicon HM and HN, Panasonic FJ and FL, Samxon GD and GC and Sanyo WG.
Old 03-07-2011, 05:25 AM   #6
Scenic
o.O
Scenic's Avatar
City & State: Duisburg
My Country: Germany
Line Voltage: 230VAC 50Hz
if they look like the ones in this photo, they're Fujitsu polys. no need to replace those.
(ignore the red boxes.. random pic i found on google)
http://www.overclock.net/attachments...l-location.jpg
edit:
15x 820F 6.3V KZG -> 1000uF 6.3v Samxon GC (8mm)
4x 1000F 16V KZG -> 1000uF 16v Samxon GC (8mm)
1x 3300F 6.3V KZG -> 3300uF 6.3v Samxon GD (10mm)
total of 8.21$. totally worth it, even if it's just an entry level board (especially since it still shows some signs of life)
The USA have Barack Obama, Bob Hope, Stevie Wonder and Jonny Cash.
We have Angela Merkel, no hope, no wonder, no cash.
Scenic is offline   Reply With Quote
Old 04-10-2011, 08:00 AM   #7
xrror
xrror's Avatar
City & State: Charleston, IL
Just a FYI on your lemon.
http://www.intel.com/support/motherb.../CS-029352.htm
One of the few ATI chipset based "Intel series" boards. If you're stuck with the emachines BIOS, you can crossflash this board to the Intel reference bios. It adds a few more features but nothing awesome.
You'll need to make a BIOS recovery disk, and remove the "BIOS Config" jumper. Sorry I don't have one of these boards still in front of me to check exactly. If you actually want to try this I still have the disk image somewhere.
You can post with a Cedar Mill chip with the Intel BIOS, but unfortunately the 3.2Ghz P4 I had it still hung after post =(
Just a FYI for if you get this working. This board is useful if you have an unused 775 Prescott laying around.
xrror is offline   Reply With Quote
Old 04-10-2011, 02:02 PM   #8
goodpsusearch
City & State: Thessaloniki, Greece
My Country: Greece
I am posting from that board right now.
It was a gift to me a year ago. It came with a nice black case, a P4 3.06GHZ HT, ATI X300 PCI-E, an LG DVD-RW and 512MB DDR2 ram.
This is how it looks today. I added a Jou Jye 460Watt psu (recapped and modded), 80GB IDE WD 7200, 1GB DDR2 667MHZ, and changed the ATI X300 with a Gigabyte 6600 GTS.
I am worried a bit about the KZGs but I am not comfortable with the idea of preventive recap on motherboards.
goodpsusearch is offline   Reply With Quote
Old 07-31-2011, 04:00 PM   #9
REMorgan
Well I got busy and forgot to post back the results of the repair. Taking c hegge's advice I used MCZ's to replace all the KZG's with success. The guy is still very happy with the repair.
Thanks to everyone.
c hegge , thanks for the "super low " ESR cap list for motherboards. Very helpful.
Old 11-18-2011, 06:50 PM   #10
goodpsusearch
My Country: Greece
Well, the KZG caps stood up to their reputation... and failed!
Today I opened the case to take out a ddr2 dimm to test another motherboard and noticed a bulging 3300uF 6.3V 10mm KZG...
There are also 4x1000uF 16V 8mm KZG caps, not bulging.
I am thinking of recapping all of them.
The other caps are poly, Panasonic, Rubycon and Chemicon KZE.
The computer is working like nothing happened. In fact it is my main rig and I am posting from it right now.
Old 11-18-2011, 07:09 PM   #11
retiredcaps
City & State: Canada
If you are going to recap the non bulging KZGs, can you measure the uF and ESR? I know they have a repuation for failing with bloating, but AFAIK, no one has measured them to definitely say the uF is low or ESR is super high.
--- begin sig file ---
--- end sig file ---
Old 11-18-2011, 10:27 PM   #12
RobertMfromLI
I've got an HP in the office right now with (at least) two bad Rubycons on it. 2 are bulged (with one leaking pretty bad). It was working fine until just now (which is actually why I stopped by). Now, the BIOS/logo screen comes up and the system turns off. Yours will probably finish dying soon too. :-/
Details for anyone interested: HP Stingray board (ie: Asus P4SD-LA with custom HP ROM and such), caps are Rubycon 6.3V 1800uf
Back to the topic at hand... I'd expect it to die. It's probably safest (and cheapest) to re-cap it now before you run the risk of something else on the board being damaged.
RobertMfromLI is offline   Reply With Quote
Old 11-18-2011, 11:01 PM   #13
c_hegge
c_hegge's Avatar
^Bad rubycon? odd. CHeck for bad caps in your PSU, since I can't inagine anything else that would kill a rubycon (unless it's an SFF roasting oven)
Old 11-19-2011, 04:29 PM   #14
goodpsusearch
My Country: Greece
Will do.
Meanwhile I just measured 3 KZJ bloated caps. They use the same electrolyte with the KZGs and are also considered unreliable. Those are 6.3V 1500uF and came out from a Gigabyte GV-NX66128DP.
1)esr: 58ohm capacity: 1.3uF
2)esr: 1.4ohm c: 321uF
3)esr: 32ohm c: 3.5uF
Old 02-08-2012, 01:34 PM   #15
goodpsusearch
My Country: Greece
I just noticed that this motherboard follows the Asus color code of the capacitors' polarity! The white marking is where the positive leg of the cap goes!
But it's an Intel! What does this mean????
Btw I took the bulging 3300uF 6.3V KZG cap out and tested it with my ESR Micro meter:
3390uF esr: 0.02
Old 02-08-2012, 02:00 PM   #16
c_hegge
c_hegge's Avatar
It means that intel used @$U$ as an OEM, as opposed to Foxconn.
Old 02-08-2012, 03:04 PM   #17
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
City & State: Phoenix, AZ
Line Voltage: 120V 60Hz
No it doesn't.
There is no standard.
They can flip it anytime they want.
You see the E210882 written on the board?
That is the UL number for Intel Desktop boards.
That means it isn't a Foxconn build either.
Foxconn's UL is E219542. [At least on their Dells.]
See page 108.
http://grox.net/misc/dox/d865perl/D8...ence.guide.pdf
Mann-Made Global Warming.
- Dr Seuss
PCBONEZ is offline   Reply With Quote
Old 02-08-2012, 04:58 PM   #18
goodpsusearch
My Country: Greece
I replaced all the KZG at this board.
For 1x Chemicon KZG 3300uF 6.3V (bulging) I used 1x Nichicon HM 3300uF 6.3V
For 4x Chemicon KZG 1000uF 16V 8mm esr 0.021 ripple 1,870 I used 4x Panasonic FM 1000uF 16V 10mm esr 0.019 ripple 2180.
I also tested the 4 non bulging KZGs and the esr showed 0.01-0.02, so they hadn't failed yet.
Old 02-14-2012, 08:33 PM   #19
Shocker
Banned
City & State: Albany, Western Australia
3390uF esr: 0.02
It's bulging!!! How can it test even somewhat close to specification!!!
Shocker is offline   Reply With Quote
Old 02-14-2012, 09:07 PM   #20
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
Not surprising really. Caps fail a number of different ways.
They bulge when the electrolyte breaks down and starts forming gasses inside the can.
The electrolyte can break down from outside causes or just because the formula isn't stable.
If it's bulged and uF and ESR are still good that suggests the electrolyte formula failing is the 'root' cause.
In other words the chemistry goes bad and causes the other problems instead of vice versa.
[That's been the suspected reason KZG/KZJ go bad for quite a while.]
It isn't likely to stay in spec much longer.
The pressure in the can will eventually create small leaks and it will dry-out.
