Badcaps.net Forum
Go Back   Badcaps Forums > General Topics > General Capacitor Questions & Issues
Thread Tools Display Modes
Old 11-16-2017, 11:23 PM   #1
KoroKoro
City & State: Sydney NSW
My Country: Australia
I'm a: Knowledge Seeker
Unhappy Weird Cap Brand? DELTEC ?
Deltec? Has anyone heard of these?
I'm just trying to replace existing caps out of a CRT, so they are quite big so I want to get the correct type.
The issue I'm having is I can't find any information on the series type / model number. I'm sure they're commonly known for the experienced, but I'm rather noob.
The cap series numbers I need info on are:
SG
SU
CE
GE
CE-GE
CE-SU
SUW-CE
CE-FL
RA
I also have quite a large number of unbranded caps. Some are black and marked JAPAN, while some others are just blue. Not sure if colour means anything for caps, like it does for resistors (brown=5% and blue=1% etc)
The rest of the caps are Samwha so I was able to get most of the data sheets. The next step will be trying to figure out what series I should replace them with (I think I will go with Panasonic).
Cheers.
KoroKoro is offline   Reply With Quote
Old 11-17-2017, 02:30 PM   #2
PeteS in CA
PeteS in CA's Avatar
City & State: San Jose, CA
My Country: USA, Unsure of Planet
Line Voltage: 120VAC, 60Hz & 115VAC, 400Hz
I'm a: Professional Tech
Default Re: Weird Cap Brand? DELTEC ?
Other than as corporate colors, sort of, the colors of the sleeves don't mean a lot. Electrolytic capacitors are typically 20% tolerance. Many have the letter "M" on the sleeve, e.g. some Rubycon capacitors I see in front of me that have "680uF(M)". I'm not familiar with Deltec capacitors.
__________________
PeteS in CA
Where might is right
There is no right.
- Sophocles in "Antigone"
All that is gold does not glitter,
Not all those who wander are lost;
- J.R.R. Tolkien, The Fellowship of the Ring
PeteS in CA is offline   Reply With Quote
Old 11-17-2017, 10:31 PM   #3
KoroKoro
I thought [M] was Matsushita Panasonic ?
I realy hope someone can help me with these Deltecs. 70% are this brand and I'm not sure what to replace them with
Old 11-18-2017, 02:26 AM   #4
mariushm
City & State: Romania
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
It's a CRT monitor. it won't require any fancy capacitors, with very low esr and all that.
Blue capacitors were often 85c rated instead of 105c but it's not a rule, i'm sure some company somewhere used blue sleeve for all their capacitors regardless of temperature rating.
I wouldn't worry too much about those as they're probably general purpose capacitors. Probably would think of using Panasonic FC , FK or Nichicon PW , HD, HE or Rubycon ZL / YX* or United chemi con lx* / ky* , whatever has average specifications and good life rating.
M is short for 20% tolerance. M in a square and with stylized endings on the legs (curved ends on the letter) is the logo for Matsushita (Panasonic)
EIA Tolerance Capacitor Marking Code
Letter Tolerance
Z +80%, -20% - this is used with electrolytic capacitors where the minimum value is the major issue.
M 20%
K 10%
J 5%
G 2%
F 1%
D 0.5%
C 0.25%
B 0.1%
mariushm is offline   Reply With Quote
Old 12-24-2017, 08:40 PM   #5
coreAngel
coreAngel's Avatar
City & State: FL
My Country: United States
Line Voltage: 120 VAC 60Hz
SG
SU
CE
GE
CE-GE
CE-SU
SUW-CE
CE-FL
RA
Cheers.
Ah yes deltec, i found craploads of those in several packages of radio shack electrolytic caps i bought, some were way off the scale, and esr was abysmal even tho it said low esr.. they had the same color as some Aishi caps, and the same on Jwco, and B.H. caps all crapola
__________________
Yes i love Nichicon MUSE Audio Capacitors...they would look awesome all over any motherboard
coreAngel is offline   Reply With Quote
Old 12-26-2017, 11:19 AM   #6
PeteS in CA
Yes, Matsushita Panasonic uses an "M" for their logo. However:
and
I could probably find examples from other brands very easily, but that should suffice to illustrate what I said above.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
