Badcaps.net Forum
Go Back   Badcaps Forums > General Topics > General Capacitor Questions & Issues
Thread Tools Display Modes
Old 12-17-2017, 05:17 PM   #1
Karagjozi_XIII
City & State: Limassol
My Country: Cyprus
Line Voltage: 230 in theory, over 240 in real life
I'm a: Knowledge Seeker
Default Rubycon caps identification
I did find some nice stash of pretty old Rubycon capacitors, type is unknown to me. Certain quantity I bought almost 20 years ago, they look as normal electrolytic but I was told that those are bipolar non-electrolytic. Any idea what type/dielectric is in question? Are they any good for audio application in valve amplifiers, or shall I discard them as worthless ancient junk? Any answer will be highly appreciated.
Cheers, Mladen
Karagjozi_XIII is offline   Reply With Quote
Old 12-17-2017, 07:07 PM   #2
ruky con
a fake rubycon
ruky con's Avatar
City & State: california
My Country: USA
Line Voltage: 122.5VAC 59.9Hz
Default Re: Rubycon caps identification
The arrows on the capacitor suggests that this is not a bipolar capacitor. As for the type of capacitor, i would say it's a electrolytic based off of it's shape and the arrows pointing at one of the legs (most likely the negative leg.)
That's hard to say, for one thing do the caps even work? If not then you're better off getting rid of them and buying new. If so then the next question would be should you use them. A lot of people would tell you to get brand new capacitors because you don't know how long those old capacitors last if you did use them, because as a capacitor ages the chemistry of the electrolyte can change which can cause the capacitor to fail prematurely (but that's not always the case.) you may also want to reform the capacitors before use. (There's a thread you can read about how to Recondition (reform) electrolytic capacitors somewhere on this site)
I hope something i said will help you.
ruky con is offline   Reply With Quote
Old 12-18-2017, 01:24 AM   #3
Karagjozi_XIII
My Country: Cyprus
Thanks ruky con,
This is exactly what I thought, regarding axial alu-can type package.
I will further investigate the possibility of reconditioning old elcos, since my stash include a lot of old ELNA, FRAKO, Nichicon and Matsushita's. These days I can't find nothing better than Samwha in local shops, and after reading posts on this forum, for sure I will stick to good originals.
Old 12-20-2017, 12:02 AM   #4
Behemot
Behemot's Avatar
City & State: Prague, 504'52.22"N, 1423'30.45"E
My Country: CZ
Line Voltage: 230 V/50 Hz
Quote:
Not really. Could just describe the best orientation. Although non-polarised caps can accept voltage in both ways, even those have a better orientation with less noise (or something) for audio circuits. Old caps had that, newer ones don't. Most ppl do not even know that, these nuances are what differentiate the best audio gear from the rest
__________________
Behemot is offline   Reply With Quote
Old 12-20-2017, 04:40 AM   #5
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
I'm a: Professional Tech
there is a vid on youtube showing how to determine the polarity of film caps at carson's lab!!
stj is offline   Reply With Quote
Old 12-20-2017, 04:46 AM   #6
ruky con
a fake rubycon
ruky con's Avatar
My Country: USA
I'm pretty sure the Rubycon capacitors he has are electrolytic capacitors. (I could be wrong but i don't think that's likely in this case)
Old 12-20-2017, 04:49 AM   #7
stj
stj's Avatar
600v???
Old 12-20-2017, 04:58 AM   #8
ruky con
a fake rubycon
ruky con's Avatar
My Country: USA
Quote:
Originally Posted by stj View Post
600v???
I have a really old 500v rated electrolytic capacitor.
Old 12-20-2017, 09:54 PM   #9
LLLlllou
City & State: NJ
My Country: USA
Line Voltage: 120VAC 60Hz
Quote:
Rip one open with a pair of wire cutters.
Cheers, Mladen
Assuming they are still within their rated specs, I'd use them. If they're paper dielectric, they would leak current like a resister. Apply 600VDC across it and measure the current through it.
LLLlllou is offline   Reply With Quote
Old 12-21-2017, 04:46 AM   #10
kc8adu
kc8adu's Avatar
City & State: dayton ohio
My Country: U.S.A!
Line Voltage: 12vdc,120/240vac,480vac 3ph on my bench
those are probably paper in oil.
very old.
kc8adu is offline   Reply With Quote
Old 12-21-2017, 08:20 AM   #11
stj
stj's Avatar
wouldnt the oil be pcb's??
Old 12-21-2017, 06:18 PM   #12
kc8adu
kc8adu's Avatar
My Country: U.S.A!
possibly.
but like many pcb caps its nothing to worry about.
modern china shit equipment is far more likely to harm you.
Old 12-22-2017, 12:55 AM   #13
Behemot
Behemot's Avatar
My Country: CZ
Yep, unless you burn and breath it or lick it there's nothing to worry about.
Old 12-24-2017, 08:12 PM   #14
coreAngel
coreAngel's Avatar
City & State: FL
My Country: United States
Line Voltage: 120 VAC 60Hz
Sorry for the late reply this is a Rubycon Audio (paper) capacitors they are vintage usually sold as NOS (new old stock) and are really rare to find.
and are usually used in single ended audio triode power amps.
__________________
Yes i love Nichicon MUSE Audio Capacitors...they would look awesome all over any motherboard
coreAngel is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
