Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Laptops, Portable, and Mobile Devices
Thread Tools Display Modes
Old 10-28-2011, 01:43 AM   #1
12ax7a
Default Acer 4530 - powers on then shuts off 2 seconds later
Acer aspire 4530 - powers on then shuts off 2 seconds later.
This seems to be a fairly common problem among many manufacturer's laptops described on the web.
Anyone know the cause / fix?
12ax7a is offline   Reply With Quote
Old 10-28-2011, 08:50 PM   #2
nish_pinto
The Adventurist
nish_pinto's Avatar
City & State: Bassien
My Country: India
Line Voltage: 220VAC 60Hz
I'm a: Knowledge Seeker
Default Re: Acer 4530 - powers on then shuts off 2 seconds later
Of what nature is the problem? Could you please elaborate?
nish_pinto is offline   Reply With Quote
Old 10-29-2011, 07:24 AM   #3
chosentestament
Does it get to POST first? If it doesn't get to POST it sounds like it may be a power supply issue.
chosentestament is offline   Reply With Quote
Old 10-29-2011, 09:29 PM   #4
12ax7a
Nope - no post. no bios writing. tried three different external adapters - all good. no difference.
Nature of the problem: Press power button.. blue LEDS do their 'go around thing' for about 1.5 seconds ... fan makes brief blowing noise .. no bios writing on screen ... unit shuts off. charging of battery & charging LED seem to function correctly. changed CPU. changed memory. disconnected all device loads - that is: hard drive, CD rom, modem, wifi, etc. DC jack seems good. same problem regardless of whether screen is connected. reapplied silver thermal paste on cpu. graphics chip heat transfer pad seems fine. same behavior regardless of battery connected or not. no obvious shorts in USB connectors or otherwise. 5V & 3.3V stand-by appear to be there. ...
Old 10-29-2011, 10:51 PM   #5
12ax7a
the consensus out there seems to be Nvidia video chip requiring reflow or reball.
everybody agree?
Old 10-30-2011, 03:12 AM   #6
trebo
City & State: Cardiff
My Country: Wales, UK
Quote:
everybody agree?
mine was acer travelmate 5320, similar symptoms, lots of lappys out there with similar symptoms, and no fixes or help
your lappy like mine is NOT known to require reflow, like some lappys DO
mine turned out to be CPU
I was about to replace the bios chip before cpu
reflow seems drastic at this stage (they dont seem to last anyway)
trebo is offline   Reply With Quote
Old 11-01-2011, 12:05 AM   #7
hotkey
My problem just same
my laptop acer 4740 die after a few minit in win
this pronlem like chipset over heat or fan run badly
i still can't solve this problem
all voltage in motherboard is good.
hotkey is offline   Reply With Quote
Old 11-01-2011, 11:06 AM   #8
specific
hi
for acer 4530 prob is around the nvidia chip
reflow or reball is recommended
its actually coprocessor not only vga
u can just heat the chip for some time and check
regards
specific is offline   Reply With Quote
Old 11-05-2011, 06:25 PM   #9
12ax7a
tried it once but i'll try it again. thanx.
Old 11-13-2011, 11:05 AM   #10
starmaxpc
City & State: Canada
everybody agree?
YES!! i had one of these laptop's. stripped in down re heated the nvidia with hot air gun and also shimmed it with a dime, yes a dime, temporary fix. still working to this day no problems. did it 2 months ago. There..... put in my "10 cents" worth! Har Har...
starmaxpc is offline   Reply With Quote
Old 12-13-2011, 05:34 AM   #11
swanand
first check with the another cpu... if problem is steel there then you will need to replace nvidia mcp77 bga chip
Regards
swanand
swanand is offline   Reply With Quote
Old 05-22-2013, 09:36 AM   #12
charlee_77
City & State: Perak
My Country: Malaysia
Nature of the problem: Press power button.. blue LEDS do their 'go around thing' for about 1.5 seconds ... fan makes brief blowing noise .. no bios writing on screen ... unit shuts off. charging of battery & charging LED seem to function correctly. changed CPU. changed memory. disconnected all device loads - that is: hard drive, CD rom, modem, wifi, etc. DC jack seems good. same problem regardless of whether screen is connected. reapplied silver thermal paste on cpu. graphics chip heat transfer pad seems fine. same behavior regardless of battery connected or not. no obvious shorts in USB connectors or otherwise. 5V & 3.3V stand-by appear to be there. .......
charlee_77 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
