P5G41C-M LX stuck on brand image
    Hi all, i have this mobo, the problem:
    i power on the pc, it show Asus Logo on screen and it hangs there, no power off, no bios acces... i have to force shutdown presing the power button or removing power supply cable.
    I cant see bad capacitors on the board.... any tip?
    Re: P5G41C-M LX stuck on brand image
    Try hotflashing a newer BIOS if the BIOS chip is a square PLCC chip.
    If that doesn't work then I'm out of ideas.
    Main rig:
    Gigabyte B75M-D3H
    Core i5-3470 3.60GHz
    16GB DDR3-1600
    Samsung SH-224AB DVD-RW
    Delux MG760 case
      go into the bios with the "del" key and turn off the quickboot logo so you can see the diagnostic text.
        He said he has no BIOS access,as it hangs on the logo.
        Main rig:
        Gigabyte B75M-D3H
        16GB DDR3-1600
        Delux MG760 case
          he may get in by pressing the button before the logo apears.
          this is why you dont set the stupid logo on in the bios.
          it may be bitching about the ram or a bad gfx card, but if you cant see it then you dont know.
          i'd like to know what cards and how many dims are in this machine!
            System hangs, no beeps, I can't enter to bios, it freezes on Asus logo screen
              did you reset the cmos with the jumper?
                yes, it was the fisrt thing i have done.
                tryed another 2 processors, varius tested rams, and the same.
                  what cards are fitted?
                    Bad PSU?
                    (just to rule this out)
                      Using PS/2 or USB keyboard ?
                      If USB, try a PS/2 keyboard to see if its Del key gets into BIOS settings
                        If this occurs with 4 sticks, take half of them out, increase the DRAM voltage, save then put the other sticks back in.
                        (Increase the DRAM voltage to 1.90 V for DDR 2)
                        ASRock B550 PG Velocita
                        Ryzen 9 "Vermeer" 5900X
                        16 GB AData XPG Spectrix D41
                        eVGA Supernova G3 750W
                        Alienware AW3423DWF OLED
                          Replace the Cmos battery with a new one, Some ASUS boards will do this when the battery drops below 3v.
                            First the aswers:
                            wirh integrated card: Nothing changes
                            with graphic card: The same thing
                            i have tried various cards, X300, hd 5450, hd 3850...
                            Originally posted by Majestyk View Post
                            Bad PSU?
                            the psu is working fine, i have tried at least 4 working PSU and no changes.
                            Im using ps2 and usb, it freezes always in same point.
                            It happen with 1 or 2 modules
                            I will try this.... I dont know that.
                            it get stuck on this screen:
                              Does the "Num Lock" key on the keyboard stop responding too? Keep pressing so that it turns ON and OFF. If it stops responding, the motherboard truly is getting stuck on boot. May need to reflash BIOS chip externally.
                                Well,he'll have a hard time flashing the chip I guess,since it's neither DIP32 nor PLCC.
                                Main rig:
                                Gigabyte B75M-D3H
                                16GB DDR3-1600
                                Delux MG760 case
                                  what is it, SPI ?
                                  if it is then it may be pretty easy from a parallel port.
                                    what is it, SPI ?
                                    Yes,it's a SPI flash.
                                    Main rig:
                                    Gigabyte B75M-D3H
                                    16GB DDR3-1600
                                    Delux MG760 case
                                      Does it have an SPI port ?
                                      http://www.mylesgray.com/hardware/fi...n-motherboard/
                                      http://mondotech.blogspot.com.au/200...spi-flash.html
                                      http://rayer.g6.cz/elektro/spipgm.htm
                                        it have pararel and serial port, i will check those links
