Computer Network Question
    I run a fairly sophisticated (if I do say so myself.. And I do! ) computer network at my work...
    My main workstation has 3 Ethernet ports and allows me to access main workstations on all 3 networks I created..
    I did a re-install of my main workstation and now I cannot see any of the other network workstations..
    NETWORK DISCOVERY is turned on, PRIVATE NETWORK firewall is turned off and all workstations have the same WORKGROUP..
    What setting am I missing??
    Re: Computer Network Question
    DOH!!
    I should note that it's Winblows 10 I am running...
      well there you go - you expected it to work??
        Touche.. It worked before I did the re-install.. That's what's so aggravating...
          I'm not sure exactly what you're trying to do network-wise....but perhaps a managed switch + VLAN's would be a better solution.
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
            Of course, needing 3 NICs is not required. Unless you ONLY want your "main workstation" to be the only host that can see all three networks (or, if you expect it to perform the routing for any other internetwork requests).
            You can even run three "independent" networks on a single fabric!
              What I need to do is to be able to access the HDs from the other workstations on my main workstation via File Manager...
                Oh yea, I am sure there is an easier way to do what I want..
                But, while I may have tooted my own horn a tad (beep beep ) I am really nothing more than a talented amateur..
                This setup allows my pin-head brain to grasp the concept and have a snowballs chance in hell of trouble shooting..
                At least it DID prior to the OS re-install
                  Then why over complicate it? Simple shares with normal security would do the trick for a closed LAN. Is it accessible anywhere from the outside (wifi)?
                  Team : 49813
                  Join in!!
                  Team Stats
                    Nope... It's a closed system..
                    The problem is, before I could just open up FILE MANAGER, click on NETWORK and all the computers I have on my network would be available.. I then click on the computer, right click on the HD and SHARE it..
                    Now, none of the computers are showing up.. See Attached..
                    Funny thing is, I can ping the workstations from my main workstation.. The workstations show up on a LAN SCAN.. And, as you see from the pic, a printer from one of the workstations shows up in FILE MANAGER..
                    But the computers themselves are not showing up at all..
                    Thanx for the reply.. Much appreciated
                      If you want to access the other sysytems with file manager you need to turn SMBv1 back on. Microsoft turned it off in one of the patches. Function Discovery Resource Publication needs to be set to automatic start in all the services of all the machines.
                        Awesome.. I'll check that..
                        Thanx..
                          I'm having trouble grasping the 3 NIC's for 3 different networks part. If it were a network which others could possibly access, and you only wanted limited portions of the network available, I could possibly see that....but not accessible from the outside, I don't understand this config at all. I've always been a KISS networker.....and would only add essential complications for various security & access scenarios (vlans, different subnets, multiple networks, etc)....but otherwise, keep it simple!
                          Team : 49813
                          Join in!!
                          Team Stats
                            That did it!!!
                            Awesome..
                            Thanx... And thanx to all the replied... Much appreciated..
                              That did it!!!
                              Awesome..
                              Your welcome.
                                Durr, I totally forgot about that. Stupid w10!
                                Team : 49813
                                Join in!!
                                Team Stats
                                  In spades... Thanx for the assist...
                                    A ping does little more than test connectivity (assuming ICMP support is enabled).
                                    Beyond the actual "physical" (OSI 1) connection (CAT5 cable, NIC, switch), the real uses of the network rely on the implementation of various "protocols". E.g., a ping relies on UDP (User Datagram PROTOCOL), thus is implemented at level 3 in the OSI model (the lowest level that supports the idea of a packet transported across a network -- though without any reliability guarantees!).
                                    SMB ("file sharing") occurs at level 5 -- as connections have the notion of "sessions" and not just individual message packets.
                                    [By comparison, FTP operates at layer 7]
                                    The point being that you need a lot more "support" (in software!) for the protocols above the minimal "physical" connection layer).
                                    [google "OSI Model"]
                                    No doubt because the protocols are not being implemented on client or server ends of the link.
                                    E.g., I can turn off ICMP support and then you'll scratch your head wondering why you can't "ping" my computer -- even though you could do so a few seconds earlier! (I "hide" one of my outward facing computers by locking down ALL of the protocol support so any external hacks just see a "dead IP address" -- cuz I want access to that computer "from the outside" but don't want any adversaries to even know it exists!)
                                      I run 3 internets, here -- but always keep them isolated from each other.
                                      My "work/personal machines" sit on the primary "private" network.
                                      This computer (email/WWW), a printer and another laptop (ecommerce) sit on the "exposed" network.
                                      A third network is semi-disposable -- used for one-off testing of devices and software before introducing them to any of the other hosts, here.
                                      I could easily set up a host with 2, 4, 8 or more NICs (I have several 4 port cards) to allow it to connect to all of these internets, independently. But, that would assume all of the hosts on the different networks still had unique IP addresses (i.e., if there were two hosts on different networks each using 192.168.1.1 as their IP, there would be no way of knowing WHICH host the workstation wanted to contact)
                                      [The "test" network was created for the express purpose of letting me change the IP of the primary host, there, to make it easier to interface with "foreign" hosts that have previously assigned IP addresses -- without having to worry about conflicts with any of the other ~50 nodes, here]
                                      But, for the most part, if you've set up separate internets, you probably want them to remain COMPLETELY separate.
                                        That's kinda what my setup is like..
                                        I have one network that runs a Public WiFi mesh...
                                        Another network runs a Surveillance system with 35 IP/Network cameras for my work...
                                        A third network is just a testing network where I can place new devices and configure them for deployment in the other 2 networks..
                                        EDIT: I should add only one of those networks (the Public WiFi Mesh) has Internet access... The other 2 are strictly Local..
