hp 15s daop5dm8co bios rev c:
    hp 15s
    daop5dm8c0 rev c :
    plz i need bios its urgent
    Re: hp 15s daop5dm8co bios rev c:
    Originally posted by shabbir.asas View Post
    hp 15s
    daop5dm8c0 rev c :
    post the full name and model of the laptop and the original bios
      hp 15s-fq1018ne
      board no da0p5dmb8c0 rev c:
        hp 15s-fq1018ne
        bios extracted from the HP site update
        DMI 480000 - 4810FF
        KEYWIN A9E000 - A9E03F
          thanks peste its working
            HP 15-dy1071wm
            Hi I need this BIOS for this laptop, the motherboard model is DA0P5DMB8C0 Rev C.
            Thank you
              Re: HP 15-dy1071wm
              Thank you
              Upload your original bios from mainboard. What's brand , model, serial ?
              Become a Badcaps supporter
              Thanks to all supporters.
                Re: HP 15-dy1071wm
                I cannot upload the original BIOS, the BIOS chip is dead. Pin 1 is shorted and using a programmer cannot even recognize it. I have a BIOS chip but it is blank.
                The laptop is the following:
                Brand: HP
                Model: 15-dy1071wm
                Serial: 5CD050L05G
                  Re: HP 15-dy1071wm
                  Brand: HP
                  Model: 15-dy1071wm
                  Serial: 5CD050L05G
                  Because i don't know your bios chip's model, so you must try of files. One by one.
                    Re: HP 15-dy1071wm
                    The BIOS Chip model is the following: 25B127DSIG
                    I will try them all and see which one works.
                      Re: HP 15-dy1071wm
                      Is this your original chip ? try with 16MB bios.
                        Re: HP 15-dy1071wm
                        Brand: HP
                        Model: 15-dy1071wm
                        Serial: 5CD050L05G
                        Pin 1 is shorted on the board or off.What model is your programmer
                          Re: HP 15-dy1071wm
                          Pin 1 is shorted on the motherboard. In diode mode it shoes 0.005V to GND.
                          The programmer is CH1341A.
                            Re: HP 15-dy1071wm
                            On the original BIOS chip Pin 1 is shorted on the motherboard as well as off the motherboard. In diode mode it shoes 0.005V to GND.
                              Does anyone has bios dump for 15s-fq1013ns
                              Hello. Does anyone has bios dump for 15s-fq1013ns?
                                Re: Does anyone has bios dump for 15s-fq1013ns
                                Post the motherboard part number , for example DA0P5DMB8C0.
                                  Exactly da0p5dmb8c0
                                    Exactly da0p5dmb8c0
                                    Do you have a bios backup you can post. You can get a bios from the hp support page,run the exe and choose copy to a location,it will extract a full bios. You need to look at your backup to find the BID number,you can flash the virgin bios but you`ll lose DMI data,serial number,feature byte etc. The DMI can be copied from your backup with a hex editor .If you can`t do that post your backup.If you havnt got a backup then try all the extracted ones and then use HP Bios config utility and/or wndmifit to add the DMI.
