Asus g751jy schemetic please rev.2.0
    Anyone pleasee asus g751jy schematic rev.2.5 , if not existing then please asus g751jt or any g751
    thank you
    Re: Asus g751jy schemetic please rev.2.0
    try this bro
      thank you very much, but this is bin file, what program do you use to open it?
        thank you
          so... schematic PLS ???
            Hello. Does anyone has yet the schematic or board view files .brd for this motherboard ASUS G751JY REV 2.0 pleease?
              I need this schematic as well.
              Been looking everywhere to no avail....
                Hi, I only have the boardview in FZ.
                  Many Thanks.
                    Which program do you use to open this file as my Board View give error
                      Hi
                      i am having no power issue here
                      after the first mosftet i have 0.15V (pulsing up to 0.8V or may be more, but too shortly)
                      and after secondary mosfet i have 3 to 4 Volts
                      I have already changed the entry mosfets PQ8801 ans PQ8802 (twice), and the regulator BQ735
                      i also removed PR8806 to be sure to have no short after AC_BAT_SYS in a sub circuit.
                      My customer claimed the battery died and after this he got this issue.
                      Did anyone encounter a same issue and fixed it ?
                      (i know i could just put a wire there, but battery would be useless, but i'd like to find he solution)
                      ty
                        bindiou,
                        I am receiving no power and no charge ability on mine. Did you get anywhere with this. I am hoping the schematic will assist.
                        Does anyone have the schematic for revision 2.5 for this board?
                          Sometimes one of the two 19V from power supply entry mosfets gets in short circuit which cause the second one to stop working (gate closed) as these two work together by reaction on the gate mosfet signal pin. Or a short circuit after the second mosfet, example a short capacitor which is most common, will cause these two entry mosfets to close, so no voltage on the board. Can be also in short one of the mosfets that powers the processor and you can check this by removing the processor from the board if have socket. More I cannot say as I don't have your board in my hands to check it and can be so many other problems.
