I have repaired this 3COM switch, it didn't power up.
At first I thought the UC3844B was dead so I replaced it. When I saw that the external PS to feed the IC was limiting the current at 0.3A, too much for the control circuit, I checked with scope the Vcc pin and I saw it oscillating.
I just put a 47uF 25V in parallel to the Ltec 33uF 50V and the power consumption dropped at 20mA and the voltage was a perfect line, on the PowerMosfet appeared the correct driving waveform.
Then I powered up the PSU and it started without any problem.
I checked the bad LTec and it was 457nF 1184Ohm, as shown in one pic.
I replaced the Ltec wit Rubycon 47uF 25V YXF.
Here attached few pics.
It is a pity to see this PS full of good caps, Rubycon - UCC on secondary side and Hitachi as input bulk cap, failing for a small Ltec.
Ciao
Gianni
Ciao
Gianni
