Sanyo Model DP47460 wors great and will play non-stop if you do not turn the sound up past 38. I have replace pretty much all the caps on the power and main board. (The caps with the red tops are the new ones) Does not matter which input you use the magic number is still 38. The tv will turn back on but if you don't switch inputs to a no signal and lower the volume it will turn back off. After about three shut downs the set has to be unpluged for awhile before it willl turn back on. I am stumped I did check the resistors on the power supply too, no problem found.
Power board # 1LG4B10Y04800
MainBoard # 1AA4B10N24700
