Asus x453ma not charging
    Re: Asus x453ma not charging
    Originally posted by piernov View Post
    English only on this forum.
    Iam sorry sir
      Originally posted by martha februarini View Post
      no, or you can ACP bc chip
      Pardon me sir
      Sorry but i can't understand with ACP bc chip... please explain me abaout that?
        SDA & SCL voltages didn't correct right ?
        Check voltages on SMBDATA & SMBCLK KBC
        You have boardview this model right ?
          Yes i have it bro, i will update again after measurement te KBC
            SDA and SCL voltages are normal, but ACOK is only 1.68v, as well as ACDRV is still 19v, do you have any other ideas, friends?
            because the DC MOSFET conditions are all normal.
              What are the voltages for SDA & SCL ?
              ACOK, SDA and SCL are each open-drain pins. Each of these open-drain pins will have a pull-up to the +3v3 rail. So expecting that the voltage reading should be the same for all 3 of these pins.
              Can you trace the circuit to locate the local pull-up for ACOK ? Once it is found, check the other side of this resistor and confirm it is +3v3. There is a chance that the PU resistor is to +1v8 but check for it with your meter.
                SDA & SCL = 3.32v more or less both are almost the same.
                gosh you're right, why didn't I realize that, should SDA&SCL be normal as well as ACOK should be normal right?
                is there a possibility that this IC is faulty?
                if ACOK has a problem, does it affect ACDRV?
                because there is no problem on the path that ACDRV passes, but the voltage is still 19v
                  how about voltage on BATDRV?
                  when it's 6v above SRN pin voltage, the BQ "think" adapter is not present and suplying system with battery
                    Hello bro
                    1-check replace battery first (check old battery voltage also sometime battery shows percentage bt there is no voltage in battery)
                    2-check sda sdl data clock line path resistors
                    3-check voltage in mosfet (short,or leakage)
                      the result of the BATDRV pin voltage is 2.81v bro, is that normal?
                        Originally posted by vinit bhandari View Post
                        Hello bro
                        hi guys, thanks for taking your time to join this issue, i have checked all mosfet on dc in , and everything is normal nothing short circuit. and the battery is still good
                          that's normal, so the BQ "see" adapter plugged in then, but what happen when you unplug adapter when the system on S0 state (full-on)?
                            no, the battery status is 70% and can't be charged even though it's been charged for days
                              I'll try to order a new BQ
                              the problem is only with acdrv=19v
                              acok=1.61v
                              I think this BQ is broken, because the dc mosfet and the resistor it passes are not short-circuited
                                See attached.
                                From the boardview files, pin #5 of the charger IC = AC_OK.
                                This is an open-drain pin so it must use an external resistor to pull-this line to the logic high level for the pin to function correctly.
                                This external pull-up resistor is PR8812.
                                1) Meter in DC volts scale (20V max is ok).
                                2) Red meter probe on the PR8812 (measure the side of this 1M resistor) - is it 3 volts here ?
                                3) Then check the OTHER side of PR8812 - what is the voltage ?
                                4) Finally, what is the voltage on the OTHER side of PR8813 (yellow pad) = the voltage that is @ AC_OK pin of the charger IC ?
                                Post each voltage reading.
                                Since this is an open-drain pin, the external resistors define the high voltage value. Being that you have 1v62 on AC_OK then yes the charger IC could be bad OR the external resistors are bad.
                                Update - capacitor PC8823 is also involved with this AC_OK signal circuit.
                                Remove PC8823 off the logic board if the AC_OK voltage remains low @ 1v62 since we know for sure that this rail should be close to 3V under normal conditions.
                                With PC8823, what is the AC_OK voltage ?
                                  See attached.
                                  PR8812
                                  PIN1 = 3.31V
                                  PIN2 = 1.65V
                                  PR8813
                                  PIN1 = 1.65V
                                  PIN2 = 1.64V
                                  I've removed the PC8823 but the voltage on PR8812 & PR8813 remains the same and there is no change brother
                                    Remove the dual mosfet (EM6K1-G) to the right side = PQ8810 (6 lead). Keep a note on the pin #1 of the device to be safe. It is the mosfet that is enabled / disabled by the AC_OK signal.
                                    Measure again the voltage on AC_OK. If still low, remove PR8813 (1K) (to isolate the AC_OK pin from the pull-up @ PR8812.
                                    Next, confirm that PR8812 pin #2 floats to +3v. After this testing, the BQ charger must be the fault as it is pulling down AC_OK rather than allowing it to float (high impedance / HI-Z) when 'high' (aka open-collector state).
                                      See attached.
                                      and this is the resistance measurement:
                                      PR8813 = 1.001Kohm
                                      PR8812 = 0.980 Mohm - 1.000 Mohm (unstable)
                                        is it safe when this mosfet is removed and given a voltage to be measured?
                                          For this case it should be fine. The signal is going to the gate of the mosfet. The mosfet is n-channel so needs a positive voltage to turn on. You are removing the mosfet out of circuit.
                                          This is to confirm if the mosfet or charger ic are pulling down this ac_ok signal line.
                                          https://www.electronics-tutorials.ws...or/tran_7.html
