Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > General Electronics Technical Discussion
Old 09-13-2018, 08:59 PM   #1
caphair
Default Importance of wicking during rework?
Iím wondering how crucial it is to remove as much of the old solder on a bga chip and corresponding PCB pads.
Is it best practice to always wick before applying fresh leaded solder? (Presuming most original solder will be lead-free)
Or could you just make a few passes with a big glob of leaded solder across the pads with the iron?
Any side effects if both types of alloys mix together?
caphair is offline   Reply With Quote
Old 09-13-2018, 09:07 PM   #2
brethin
City & State: Owensboro, KY.
Line Voltage: 120VAC 60Hz
Default Re: Importance of wicking during rework?
Whatever works best for the job, no problems with mixing.
brethin is offline   Reply With Quote
Old 09-14-2018, 03:14 AM   #3
stj
stj's Avatar
City & State: Europe
most wick wont work well with lead free solder, the makers have not bothered to update the flux formula yet.
Old 09-14-2018, 05:56 AM   #4
caphair
So it won’t affect melting temp or not mix properly if all the old solder isn’t removed first before reballing? There’s conflicting info about the subject when I searched.
Some say it creates poor connections that can cause issues
Old 09-14-2018, 06:21 AM   #5
diif
City & State: Midlands
My Country: England
I've always cleaned with a ball of leaded solder followed by removing the rest with some decent braid. I've never had any issues.
Of course it all needs removing, otherwise there will be uneven melting of the leaded solder on the BGA whilst the motherboard still hasn't melted due to the lead free.
Why wouldn't you remove all the leaded solder ? it's not difficult or time consuming.
diif is offline   Reply With Quote
Old 09-14-2018, 06:33 AM   #6
llonen
City & State: united kingdom
My Country: hampshire
Line Voltage: 240 VAC 50Hz / 110 VAC 50 Hz and 415 VAC 50Hz
Always remove as much of the remaining solder for bga rework, come to think of it for rework really, SMD or otherwise although I make use of a pace solder extractor for through hole plated stuff and if I am feeling particularly lazy I will use on single sided non plated through rework as well. I don't have problems with lead free and various wicks but then I add flux anyway.
llonen is offline   Reply With Quote
Badcaps.net Technical Forums © 2003 - 2018
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
