Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > General Electronics Technical Discussion
Old 09-12-2018, 05:14 AM   #1
capullaco
Default Problem with mechanical keyboard
I have a James Dlonkey 619 keyboard, which lately has been having problems with the "2" and "A" keys, so I opened the keyboard to change the "Pause" and "Scroll Lock" switches for the "2" and "A" ones.
One of the problems, is the mini usb PCB connector, was badly soldered, and it had some glue to make the connectors stand still (I already removed the glue in the pics):
https://imgur.com/l7hKrpT
https://imgur.com/T90CeYi
So I used a logitech mouse cable instead, since it has the same connector, but the keyboard doesnt work. It lights for a second, blinks 3 times, then turn off. Could it be because it needs that small PCB? the other side of the USB is just plain, doesnt have any component besides the USB connectors.
I also thought it could be because one of the leds (they are on the top of the switch, you can see them on the second pic, those 2 small solders on top of every swtich, with a + sign) fell, and I soldered without checking if they were placed correctly (the + sign), since I dont know it makes a difference or not, so I desoldered this led, but still the same problem.
What could it be?
capullaco is offline   Reply With Quote
Old 09-12-2018, 09:16 AM   #2
stj
stj's Avatar
City & State: Europe
Default Re: Problem with mechanical keyboard
you wired it wrong,
that lifted track goes to a pin you need.
search usb pinouts and you will find what you need
Old 09-12-2018, 02:20 PM   #3
capullaco
Thanks, I bought a USB mini breakout board, will see if that fixes the problem.
Old 09-12-2018, 03:41 PM   #4
stj
stj's Avatar
yea, you can buy small pcb's with mini or micro usb sockets on them for breadboarding - i have some.
get them in 10's for a $ or 2 on ali-express.
Badcaps.net Technical Forums 2003 - 2018
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
