Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > General Electronics Technical Discussion
Old 09-08-2018, 10:28 AM   #1
dicky96
dicky96's Avatar
City & State: Gran Canaria
My Country: Spain
Line Voltage: 220V 50Hz
I'm a: Hobbyist Tech
Default QFP128 desoldering / rework question
Hi guys
I have to change a QFP128 chip for a repair I am doing. I've replaced 48 pin QFP chips (such as AS-15) before a few times but never a QFP128
With the AS-15 I basically add some 60/40 solder to the pins all around to reduce the melting point, apply flux and use the hot air station to unsolder.
I then use drag soldering with 60/40 and use flux plus desolder braid to clean up the shorts between pins and a jewellers loop for close examination of the work
I was thinking maybe of trying the same technique on the QFP128 but maybe to use something like Quick Chip low melt solder
Just to make things more complex this is a double sided PCB with a lot of SMDs on the other side underneath where the qfp128 is
Any suggestions?
Rich
dicky96 is offline   Reply With Quote
Old 09-08-2018, 11:35 AM   #2
CapLeaker
Leaking Member
CapLeaker's Avatar
City & State: Atlantic Canada
My Country: Canada
Line Voltage: Ground, 0Hz
Default Re: QFP128 desoldering / rework question
cut off all the legs with an exacto knife or dremel tool, then take the legs off the PCB with lots of leaded solder and solder wick? It all depends on how much room you got.
Old 09-08-2018, 12:01 PM   #3
R_J
City & State: ☻
My Country: Canada
I agree with the above, most damage occures trying to remove a bad ic all at once, just be carefull not to cut any traces
R_J is offline   Reply With Quote
Old 09-08-2018, 05:17 PM   #4
dicky96
dicky96's Avatar
My Country: Spain
To be honest I used the technique of cutting off all the pins a lot when working on through hole with internal ground plane / layers / vias and found that is the best way of working on those boards
With SMD DIL or QFP I found that coating the pins with flux then applying a liberal amount of 60/40 to all sides of the chip with a soldering iron (so effectively I have one area of solder on each side, all pins shorted together) then using the hot air station to desolder works very well
But as I mentioned i never tried on something with so many pins as QFP128
What got me wondering about using very low melting point solder alloy was videos such as this one https://www.youtube.com/watch?v=ezYcYF94_k4
That looks like a good bit of kit - a bit expensive but not stupidly so.... if you do this for a living. But I would think a cheaper way to heat the PCB would work just as well, its mostly down to reducing the melting point of the solder
I never tried this Quick Chip stuff before though and it seems expensive to me. Anyone used that or can suggest a cheaper alternative? There are products such as this on ebay https://www.ebay.co.uk/itm/Low-Melt-...4AAOSwEK9UEZBr and others that seem similar and are a lot cheaper but are they any use for this sort of work?
Old 09-09-2018, 07:47 PM   #5
NCSailor
City & State: NEW BERN, NC
My Country: United States
Line Voltage: 120VAC 60Hz
I would be hesitant to cut the legs... Too easy to cut any tracks that run from the pad under the chip.
Chip Quik is a little expensive but it works and it is a lot cheaper than replacing a damaged PCB or at a minimum repairing some pads and tracks.
I suspect that some of the other low melting point products work also, but the Chip Quik kit https://www.chipquik.com/store/produ...ucts_id=210001 comes with good flux and a proven product. It is enough to do quite a few chips and good to have on hand.
NCSailor is offline   Reply With Quote
Old 09-10-2018, 01:09 AM   #6
llonen
City & State: united kingdom
My Country: hampshire
Line Voltage: 240 VAC 50Hz / 110 VAC 50 Hz and 415 VAC 50Hz
I used to use a generic low melting point solder which was the same as quick chip, which I purchased by the roll until I invested in a half decent hot air rework station (Hako FR802) when I am back at the workshop later today I will see if I can find what solder I used to use.
llonen is offline   Reply With Quote
Old 09-10-2018, 10:33 AM   #7
dicky96
dicky96's Avatar
My Country: Spain
Hey that would be useful info if there is a cheaper alternative that does the same job.
Actually CPC/Farnell Have the chip quik kits in stock for just over 10 + VAT and free postage on orders over 8 in the UK. So I think I will order some and give it a go - my missus is back in the UK this week so she can bring over to me
One thing I'm a bit confused there is a SMD1 Chip Quik kit and a SMD1NL Chip Quik kit for very similar price, the NL being the lead free one.
As Chip Quik is meant for desoldering not for soldering, is the NL kit supposed to be better for removing components from lead free boards, in as much as it works better on higher melting point lead free solder, or is it just intended not to leave traces of lead on the board after rework - if you were bothered by that sort of thing?
Rich
Old 09-11-2018, 06:15 PM   #8
llonen
Right you are looking for commercial solders that contain the following
51%In / 32.5%Bi / 16.5%Sn (60C eutectic)
66.3%In / 33.7%Bi (72C eutectic)
57%Bi / 26%In / 17%Sn (79C eutectic)
54%Bi / 29.7%In / 16.3%Sn (81C eutectic)
This site are the one I have used in the past
https://www.somersetsolders.com/sear...%20Temperature
https://www.somersetsolders.com/tin-...der-paste/p195
A little more expensive than I recall, but they used to do smaller quantities. The main problems I used to find with this stuff amongst others it used to leave a hard to remove deposit which I found would interfere with subsequent soldering / rework.
Hope this is helpful
Old 09-11-2018, 08:01 PM   #9
momaka
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
Just use your hot air station to unsolder the chip. If board is "extra tough", put it on a grille atop your kitchen's stove top / burner, and put the heat to low (both gas and electric burners are okay). Let the board heat on the bottom for a minute or two, then blast the chip with your hot air station from top. The solder should melt a little quicker and the chip should come out easier. Just make sure you don't try to pull the chip with the solder still not melted, as that can pull traces out. One thing I do to avoid that is I give the chip a little nudge when I think it has reached temperature. If the chip moves easily on all corners, it's ready to go. If any corner feels stuck, keep heating a little more (or crank up the temperature a little bit).
Badcaps.net Technical Forums 2003 - 2018
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
