Go Back   Badcaps Forums > Motherboards with Bad Capacitors > ECS - EpoX - Gigabyte
Old 11-26-2006, 09:06 AM   #1
Rainbow
City & State: Slovakia
Default Ga-8siml
They put GSC crap next to Sanyo and Panasonic caps...
Rainbow is offline   Reply With Quote
Old 11-26-2006, 06:49 PM   #2
Shroomie
City & State: New Hampshire, USA
Default Re: Ga-8siml
Enough to make you angry. If they use good caps elsewhere, can't they fill the whole section with them? At least use a better bad cap.
You know there's something wrong when you open up a PSU and are glad to find Teapos.
Why I don't buy cheap cases!
Shroomie is offline   Reply With Quote
Old 11-26-2006, 10:02 PM   #3
Big Pope
Approved Vendor
Big Pope's Avatar
City & State: Hong Kong
I also have recapped same mobo last month, take out 4 pcs 3300uF 6.3v D10mm.
Also, i recapped all 25v 330uF with 6.3v 1500uF D10mm at once, excellent.
My SAMXON Capacitors Database HERE!!
X-CON is a new brand for SAMXON's Polymer Capacitors.
Big Pope is offline   Reply With Quote
Old 11-26-2006, 11:01 PM   #4
Topcat
The Boss Stooge
Topcat's Avatar
City & State: Salem, MO
My Country: United States
Line Voltage: 120VAC 60Hz
I just got one of those in for recapping last Friday... LOL
What an insult to Sanyo.... Gigabyte should be ashamed of themselves!
<--- Badcaps.net Founder & Owner
Badcaps.net Services:
Premade Capacitor Kits
Badcaps.net Capacitor Master List
Motherboard Repair Services
If you've come here in search of replacement capacitors or repair services, please use the links above.
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats
Topcat is offline   Reply With Quote
Old 11-28-2006, 01:21 AM   #5
yanz
yanz's Avatar
City & State: Dago, Bandung, Indonesia
shame on you, gigabyte
yanz is offline   Reply With Quote
Old 09-30-2007, 10:42 AM   #6
Harvey
Harvey's Avatar
Hmmm, I'm guessing there's a number of revisions of this board. I have one in front of me with no obvious rev. no. on it, yet it looks different to both this Rev1 pictured above and the Rev2 shown in this thread http://www.badcaps.net/forum/showthread.php?t=3244
Mine has a heat sink over the mosfets and all nichicon caps.
It appears to have a RAM power fault as holding the RESET button brings the DIMM LED on, but on releasing reset it goes out.
I shall have to investigate it more.
Harvey is offline   Reply With Quote
Old 03-12-2008, 12:52 PM   #7
Leopard
City & State: Tampere
My Country: Finland
Line Voltage: 230VAC 50Hz
One of my friends had this board on his older computer. The exact same four 3300F 6.3V GSC caps were bulging and leaking. Seems to be a common problem with those caps / the board...
The leaking caused the CPU voltage go up and down all the time. It usually got pretty hot and rebooted a few times. Luckily we built a new pc for him so he got rid of the crapcapped board. A motherboard should never go to waste, so would it be wise to recap the board?
Leopard is offline   Reply With Quote
Old 03-12-2008, 09:14 PM   #8
starfury1
starfury1's Avatar
City & State: land of OZ
GSC caps from around that period are liable to be all extreme crap.
If the MB was functional when pulled from service yes very good chance recap
will have it humming along
it is possible for badcaps to take out other things but mostly you will be ok
in the photo posted the green caps look like Sanyo WG they should be fine but check the MB for other know crap
(I am not sure of the construction but possible the GSC have caused damage to Sanyo by placing a greater work load on them...really depends on whats doing what, mostly caps are grouped in area's of operation and not good idea to mix and match caps in VRM output )
Replace ALL crap GSC if popped or not with low ESR quality types read the posts around here for recommended
Samaxon ...panasonic FM Ruby MCZ etc
size may be more your issue. so samaxon might be the way to go
Cheers
You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
starfury1 is offline   Reply With Quote
Old 03-13-2008, 08:20 AM   #9
starfury1
starfury1's Avatar
Thanks to Davmax
I have a spelling mistake above, really important as its a brand name
That should read "SAMXON" (not Samaxon)
Not sure if this still applies
State Side (USA) Contact Top Cat
ROW contact Big pope
(have I got that right?)
Cheers
Old 03-13-2008, 01:38 PM   #10
Leopard
My Country: Finland
Yep, the board is fully functional. The voltage did go up and down but he never used it for anything stressing, since a 1.7GHz Celeron paired with a SiS 650 IGP graphics chip can't play any games that well =P
I live in Finland and capacitors are a little hard to find here online. Sure, there would be tons of 'em in an electronics store, but it would be a lot handier to order them online.
I found THESE. They are Sanyo 3300f 6.3V caps, 12.5mm in diameter and the height is 20mm. MV-WX series. Are those any good/would they fit?
Old 03-13-2008, 05:01 PM   #11
davmax
davmax's Avatar
City & State: Perth Western Australia
These on eBay would do well and they are 10mm diameter, would fit better.
http://cgi.ebay.com/SANYO-WG-6-3V-33...742.m153.l1262
davmax is offline   Reply With Quote
Old 03-13-2008, 05:32 PM   #12
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
City & State: Phoenix, AZ
Line Voltage: 120V 60Hz
Link does not take me to a product.
The originals look like 10mm but hard to tell.
12.5mm replacing 10mm next to CPU socket would be difficult and maybe impossible.
GSC 3300uF 6.3v [old caps]
10x25mm, ripple:2250, ESR:0.017
12.5x21mm, ripple:2360, ESR:0.021
Sanyo WX 3300uF 6.3v [proposed caps]
12.5x20mm, ripple:2360, ESR:0.021
There are many brands that make 3300uF 6.3v in 10mm an not to hard to find ones with better specs. (Though WX is apparently good enough to match originals if they are 12.5mm.)
If there are Sanyo around there look for WG series to get 10mm and better ratings.
Mann-Made Global Warming.
- Dr Seuss
PCBONEZ is offline   Reply With Quote
Old 03-13-2008, 07:44 PM   #13
davmax
davmax's Avatar
If you can pay via Paypal I suggest you email Joe at puiyiulo@yahoo.com.hk
He will post you exactly what you require.
Badcaps.net Technical Forums 2003 - 2018
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
