hp 840 g6 6050A3022501-MB-A01
    Re: hp 840 g6 6050A3022501-MB-A01
    Originally posted by peste View Post
    no, but you can unlock yours with this program ... don't forget to back up your laptop's original bios before writing.
    https://www.badcaps.net/forum/showth...ght=rcunlocker
    Mine with absolute persistence module enabled. It activates whenever I connect on the internet and popup message appears. I bought the unit last week via company pullout post on a page. Can you disable that problem or if you have I just need the manufacture mode enabled firmware
    Thanks in advance!
      Re: Need bios EliteBook 840 G6 6050A3022501-MB-A01
      Originally posted by unlockdev View Post
      bios damaged any one has this bios
      HP EliteBook 840 G6
      Become a Badcaps supporter
      Thanks to all supporters.
        Thanks in advance!
        @i4mm3
        Post the original BIOS, I will enable manufacturing mode.
          Originally posted by onizzbox View Post
          @i4mm3
          It was already unlocked without BIOS password. Here is my bin file. Thanks in advance.
            @i4mm3
            And here is my 32MB File
              @i4mm3
              DM sent
                DM sent
                @i4mm3
                MPM - Product information:
                1. Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPhKhkjhk8.gn
                2. Build Id: 19WWCFCT601#SUUF#DUUF
                3. Serial Number: 5CG03050KY
                4. SKU Number: 7UA41UC#UUF
                5. Product Family: 103C_5336AN HP EliteBook
                6. SB CT Number: PHWGH00WBE06H4
                7. Product Name: HP EliteBook 840 G6
                Note: The following product information must be re-programmed into the (system board).
                The (Feature Byte) is case sensitive and do not leave any blanks while filling the Build Id.
                  Help unlocking bios password. do i just drag each bios dump to RCunlocker and rewrite the unlocked bios.
                  attached both dumps if someone can help
                    SORTED IT..... Bsolution sent me the unlocked files
                      Well thanks for letting us know,now nobody will waste their time trying to help you in this thread. Please read the rules regarding posting multiple requests
                        hp elitebook 840 g6 ,pls help remove password thanks..
                          Plz remove startup errors need help
                            https://www.badcaps.net/forum/showpo...1&postcount=90
                              Try
                                not working
                                  working but show errors
                                    I think this is a bios mod specifically for a company or an organization. Try rebuilding the bios file from the manufacturer's homepage.
                                      i have no idea rebuilding bios
                                        Try
                                          Try
                                          thankyou so much display ok but show errors on startup
