Homemade 2.4GHz Bi-Quad Wi-Fi Antennas
    Homemade antenna's I've made on the cheap. Why buy?
    Various designs based on 2.4GHz Bi-Quad designs. Incredibly powerful design using basic copper wire culled from common AC house wiring.
    Folding Colander design
    This thing has been in the kitchen since I was a kid, and since I never used it for it's original purpose. (boiling veggies,etc in a pot) I decided to try to make some sort of antenna with it. The shape was interesting enough, and 1st thought I could make a parabola type with it. After measuring and calculating the diameter to center angles, I found it would have made a very crappy parabola reflector, BUT, the reflector area was good enough to use it as a normal wi-fi antenna.
    The 2 most important parts of making this antenna is the wave length and exact mounted distance between the antenna and back reflector.
    Making the main driven element for 2.4GHz is simple, in the States, 2.4GHZ is spread through 12 channels, so ya want to get as close to the middle of the band as possible, so shooting for ch6 is the goal.
    Ends up the main element will be made with 1/4 wave lengths of 31.25mm lengths.
    I took an old hotel key card, measured & cut it to size,measure my wire then took needle nose pliers butted up and bend at right angles, ya could also use a cut straw to measure.
    you'll end up making a bow-tie type consisting of 2 squares, where the center will have a final right-angle bend to mount to reflector. the entire element MUST be exactly mounted 15mm from reflector. A low-loss coax cable (50Ω) with an SMA connector is attached, with the ground being soldered to the reflector/main driven element base, the center conductor will be soldered to the lower middle bend of the element
    CD case design
    CD spindle cases work great, gonna have to cut out a circle of metal for the back reflector, put the lid back on it to weatherize the element.
    Parabolic Dual Bi-Quad design
    For the reflector on this one, I cut it out from an old TV back cover, to achieve the proper curve, I rolled it using a pin-roller, laying the metal on something like a cushion, I included a PDF with the proper bend angle
    (PS: where the square says 100mmx100mm, cut in 1/2 100mmX50mm)
    Find the center after cutting and mark it.
    The driven element is a bi-quad design X 2, bending the same way as a single, but also you're going to have a couple 62.5mm lengths in it (31.25mm x 2)theres 2 points where the wire will cross each other, it's crucial to insulate them to prevent shorting. Use a piece of heat shrink or save a couple bits of the stripped insulation.
    I used an old broken GPS suction-cup mount and fashioned a holder from 2 pieces of coat hanger.
    the double bi-quad is a powerful one, roughly 13-14 dB gain w/ about a 1/2 mile range.
    Best external network card IMO is the ALFA USB, 2000Mw (18-28$ flEbay)
    SMA pigtails from China (5 for $2.48) (flEbay)
    "Our technologies have surpassed our humanity" ~Einstein
    Re: Homemade 2.4GHz Bi-Quad Wi-Fi Antennas
    You are a genius. Nice post and very interesting information. Thanks.
      according to my old man, I'm a moron and a failure in life...LMFAO
      fak 'em
      thanks Andrew
        You proved him wrong, Bro. I'm sure he couldn't design this...
          Works great with old satellite dish also.
          For adapters etekcity from ebay was another good one cheaper than alfa. Although ubiquiti bullet with a dish or yagi is tits.
            I made one of these in college for my electromagnetics class. I still have it somewhere, assuming the steel ground plate didn't rust too horribly.
            Better than one of my classmates who used an old CD-R spindle and some aluminum foil for his reflector... he had the fabrication skills of a teddy bear.
            sigpic
            (Insert witty quote here)
              I was thinking of mounting a usb wifi adpt. in the center of a sat dish antenna just to see how well it would do .
                it wont, it needs to be on the end of the feed arm and you need to point the dish taking into account the angle the signal is deflecting onto the arm.
                infact it will work better if you keep the lnb casing to use it's feedhorn - it's matched to the distance and angle from the reflector.
                  fak 'em
                  thanks Andrew
                  He's just jealous and proud at the same time :P Good job OP.
