Rtl8169
    Rtl8169
    are these chips supposed to get so hot that even with a heatsink they cant be touched??
    Re: Rtl8169
    0-70c operating temperature according to the data sheet.
    I wouldn't have thought it should be too hot to touch though. I've seen them in laptops and they aren't heatsinked.
      Re: Rtl8169
      hmmm.
      i have 2 pci cards.
      one netgear - naked.
      one chinese - with a sink and frankley better made.
      i tested the chinese one and just idling for 15mins without any data transfer it was generating some serious heat - but worked fine when i fired up firefox for a test.
      i think i'll dig the netgear out for a comparison.
        Re: Rtl8169
        Interesting, let us know what you find.
        Better made ≠ better designed though.
          Re: Rtl8169
          most things like this are all based on the reference design though.
            Re: Rtl8169
            Did the chip on the Netgear get hot ?
              Re: Rtl8169
              All my 8169 chips on the ethernet boards I have stay fairly cool.
              The only thing on these boards that get hot are the VRs on the boards.
                Re: Rtl8169
                the netgear was screwed,
                but i decided to look at the regulators on the chinese one and the resistance between input and output was only a few k - very suspect.
                they are 1117's - so i'll pull then in the next couple of days and meter them off-board.
                  Re: Rtl8169
                  If it's a real rtl8169 it should only average about 0.5W - this should be enough dissipation to feel something but it should not burn your finger off nor need a heatsink (unless it must stay cool).
                    Re: Rtl8169
                    interesting design, i must say
                      Re: Rtl8169
                      Realtek cards are poor performers, but only saw then overheating after a lightning strike.
                        Re: Rtl8169
                        I've seen a lot of hearsay that rtl8169 chips are poor performers but no actual benchmarks. I do not expect it to match top cards but from my experience with them, they are more than "poor" - they're quite acceptable for many uses. Is there a benchmark where the rtl8169 is less than 60% the speed of another ethernet solution, and how often does that benchmark happen in real life?
                        Oh, and do not count rtl8169's put on PCI 32-bit/33MHz busses... that's known to be a bottleneck...
