Cap Identification please.
    Re: Cap Identification please.
    Originally posted by Behemot View Post
    None of those pens will ever work as well as transformer soldering gun, it's just physics.
    A temperature controlled Weller or Metcal with a reasonably high mass tip would probably do OK. Not that Weller is cheap or Metcal is in any sense inexpensive.
    PeteS in CA
      I am not exactly sure what is reasonably high mass tip, but I use 2.5mm^2 solid copper wire for my 150VA gun.
        I don't think its vrm out, so I would not risk 2.5v.
        the 3.0 version of the board had the cap as a real polymer there, I think its a reg cap for that chip up there
        the output vrm is lytics
        http://static.nix.ru/autocatalog/mot.../53036_top.jpg
          The image in that URL shows wet electrolytics, not polymers. Those are sleeveless Panasonic FL without a vent stamp. Behemot dissected some 6+ years ago.
          The font on the failed 680uF 4V capacitors reminds me of Suncon (formerly Sanyo's electrolytic division). The font and vent stamp are both a match.
            Seems like these custom short caps were quite common for a time of the 775 era. Always around the socket, under heatsink.
