Mosfet goes from reading to OL
    HI guys
    I have a Toshiba Mosfet K3569
    When I test it, the reading between D and S (after turning on) get from a voltage and getting higher until OL in an seconde or so. Is that a normal situation or a bad MOSFET?
    All bad mosfet video I saw on youtube only show shortened reading between D and S .
    And sorry if my english is bad!
    Re: Mosfet goes from reading to OL
    It is normal, testing a mosfet from D-S, the gate is sensitive to static charge.
    If you first "charged" the gate to turn it on, then it will slowly lose charge with the gate not connected.
    You must short G-S to ensure mosfet is off. Then look for a short or leakage across D-S.
    To look for a short or leakage across G-S or G-D, there is nothing to worry about.
      I just changed 2 brand new mosfets that tested perfectly fine, but wouldn't close the gate with a load... so just replaced them with budm recommendations..
