dalco atx500w(powmax re-label)
    dalco is a local pc parts distro.
    this appears to be a rebadged powmax in a pretty case.
    same crap different day
    a mix of jee,asiacap,and teapo
    several of each blown open.
    this is less than a year old.
    dont let the pretty aluminum case fool you.
    500w my ass!
    Re: dalco atx500w(powmax re-label)
    What is the black stuff on the cap in the middle that does not look blown? Same goo that looks to be on the coil?
      Looks like some kind of crap-glue. Maybe the one that's yellow and turns brown somewhere (from heat?) - I've this in some PSUs.
        its cooked glue and cap juice.
          Does anyone know about Asiacap capacitors? I have never heard of this brand before. (Picture if possible?)
            i will pull one and take a pic.
            the ones in this unit are black/gold with honeycomb vent
              Epoxy with an electrolyte chaser? Do you take that with an olive or a maraschino cherry?
              PeteS in CA
                i did not find info about asiacap on the net. are we sure about the spelling? perhaps it is so crap and therefore no site.
                Cheers Pete!
                  these are the first i have seen.
                  i will be back at the shop mon.and will post pics.
                    You mean Asiacon? These are sometimes seen on Acer or Wistron OEM PSUs. They're better than Arcon, but that's like saying that Choyo is better than GSC.
                      I didn't find Asiacon's website. I'm guessing they are so shitty that they have no website at all.
                      My gaming PC:
                      AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
                      ASUS M4A77TD AMD 770 AM3 Motherboard
                      PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
                      G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
                      TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
                      WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
                      ASUS Xonar DG 5.1 Channel PCI sound card
                      Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
                      Antec Three Hundred Mid-Tower Case
                      Microsoft Windows 10 Pro 64-bit
                      Microsoft Windows 7 Ultimate SP1 64-bit
