Laptop's AC adapter turns off when connected, corrosion on power-related components
    Re: Laptop's AC adapter turns off when connected, corrosion on power-related componen
    yes, PR603. it's a shunt resistor for VRAM power supply circuit and luckily it's not beep and displayed "1" in your multimeter like PL601, i assumed VRAM power supply is safe.
    for PL601, PL602 & PL603 it's surprising not showing a value between 200-500 in your multimeter. i hope not the graphic chip make the shorts...
      OK, I've removed PL601, PL602 & PL603!
      Though, I accidentally confused PL601, PL602 & PL603 with PL501, PL502 & PL503 and removed them first! From what I've read, these components are "SMT power inductor" and have no polarity, so you can solder them in any direction. I've re-soldered PL501, PL502 & PL503, so hopefully there's no problems!
      Anyway, here's the readings I'm getting:
      PL601 right solder pad (as in previous photo) - beep and "-001". Both colored probes get the same result.
      PL601 left solder pad (as in previous photo) - no beep and "78" with the black probe on the solder pad and red probe on ground. No beep and "472" with the red probe on solder pad and black probe on ground.
        yes, inductor have no polarity. so you can solder it in anyway.
        i've got confused with this, oh wait....
        i had to read over and over to understand what you meant
        you always should place black probe on ground and i think the shorts in graphic chip area, thats bad...
        but, if you want to try more, you can remove smd capacitor near the graphic chip. it's in page 66 on schematic, but you can try to remove PC966, PC967, PC969 & PC970 then test again using continuity to ground on PL601 right solder pad
          Sorry, I thought I explained it clearly!
          Oh, I thought the fact that the different probes give different results was useful, so I thought I'd tell you which happens with different probes.
          Hmmmm, if the short is in the graphics chip area, does that mean the short is probably in the GPU itself? That's probably not something someone with a soldering iron can fix, is it? Where do you think we should go from here? Should I give up and leave this to a professional electronics repair lab? Or do you think it's worthwhile to try removing PC966, PC967, PC969 & PC970 then test again using continuity to ground on PL601?
            i dont have the schematics, but i think that if u desolder the pjp point where it gives the 1.5 volt for vram, it will disable the discrete vga and work with just the integrated one. in addition as i have said before, board was previously put in a oven, so dunno what else could be bad now .....
            to see if a short is gone, put psu again and if light stay on then short is gone.
              Ah, so you're saying if we can get the laptop to switch to integrated GPU, and it start up, then the short is with the discrete GPU? Is the "PJP" point you mentioned the "PJP600" solder bridge we removed before? How about the ripped solder pad on that chip I showed you before? The laptop won't boot with that not fixed, will it?
              Yes, I mentioned this before, but after re-soldering the components we removed (MOSFETs etc) and those two solder bridges, I connected the AC adapter and the LED light on the AC adapter stays on!
                OK, I soldered those SMT power inductors back and did a partial assembly, by plugging the AC adapter and battery back in. I plugged in the AC adapter, and while it LED didn't go out, there didn't seem to be any sign that the battery was being charged (i.e the AC adapter or battery didn't get warm). Apparently with this laptop, the charging indicator is the power button on the keyboard, so I plugged in the keyboard too, but the power button didn't light up.
                Does the entire laptop need to be reassembled before it will charge or something? Or is there some other problem?
                  dunno that model in particular, but on my old m17x r4, all light were on the plastic covering the top case, the one that cover the keyboard screws and so on with the hole for the alienware power botton.
                  alienware power botton got just some hdd light in it, while that plastic got all other lights.
                    I fully re-assembled the laptop and tried plugging it in and turning it on. The laptop lights up! It doesn't boot though, and nothing appears on screen, it just beeps 7 times. Google seems to indicate that 7 beeps means a RAM problem, so I've tried swapping which DIMM the RAM is installed in and even booting with no RAM, but it still beeps 7 times.
                    THIS GUIDE suggests clearing the CMOS, but that didn't help.
                      7 beeps in dell doesnt mean ram failure-it means processor failure. So you need to check vcore circuit.
                        Ah, I see. Would it be the GPU or CPU? If it's the GPU, that would line up with what was said before about there probably being a problem in the graphics area of the board.
                        Is the vcore something we've already tested in this motherboard? It sounds familiar. If not, after we've finished testing, would fixing the problem be a simple matter of replacing a dead capacitor, MOSFET etc or are are looking at something more complicated, like a BGA?
                        Oh, and before I forget, there's still the lifted solder pad problem with UH3:
                        I'm going to take a wild guess and assume that this will need to be fixed at some point!
                          where can we find the schematics ?
                            This is apparently the schematics for my board:
                            https://www.badcaps.net/forum/attach...0&d=1524883267
                              uh3 is PLT_RST so is needed for good working.
                              with powered pc on, check uh3 voltages, pl502 pl503 pl504 voltages.also check pu500 pu501 pins voltages. always be carefull when checking.
                                Sounds like it's important!
                                OK, I've here's the voltages:
                                UH3: 3.28v (on pin 1 & 5, nothing on the other pins) (multimeter set to 20v)
                                The next components are bit tricky, since they're under the heatsink and only one solder point of each component is exposed. Also, I can only see the label for PL502, the labels for PL503 and PL504 are covered by the heatsink! But from what I can recall, PL503 and PL504 are the two SMT power inductors next to PL502. Anyway, here's the voltages:
                                PL502: 1.572 (multimeter set to 2v)
                                PL503?: 1.591 (multimeter set to 2v)
                                PL504?: 1.448 (multimeter set to 2v)
                                As for PU500 and PU501, I'm having trouble finding them! I've found the label for PU500, but there's a bunch of different components nearby:
                                Is the nearby chip PU500?
                                Oh and if case it helps, I touched the heatsink and the areas around the CPU and GPU were warm, so it looks like they're getting power.
                                  im reading again the discussion. so the problem making psu to turn off was pl601 ?
                                  edit: remove pjp302 pjp304 pjp305 and power on pc again.
                                    Not PJP601, PJP600. After I removed this solder bridge, (and also cleaned up the solder mess on UH3 and re-soldered the components I had removed before) the LED on the AC adapter stayed on when it was plugged in.
                                    *EDIT* (I didn't see you had edited your post!) I've found pjp302 pjp304 pjp305, but are these correct solder bridge to remove if my problem solder bridge was PJP600 and not PJP601?
                                      yes remove those pjp 302 304 305 and see if notebook works.
                                        OK, I've removed pjp302 pjp304 pjp305, but I still get 7 beeps when I try to boot.
                                          check resistor near cpu power ic, as 1.4 volt output is too much i think.
