Hi All!
I have inherited a PS-50A457P1D, and have a small problem!
When I switched it on, it seemed fine, then a series of verticle white lines with a pink line in the middle appeared, just left of centre.
Did a bit of research, and found it could be a loose cable. I carefuly reseated all the ribbon cables, and fired her up. Lines all gone! BUT! Now, the right hand quarter of the screen no longer works. everything else seems fine. By disconnecting the ribbon cables that leads down to the boards at the bottom, one at a time, then powering up, it shows that the screen itself is getting power on that side and lighting up, it just doesn't get the picture.
As I understand it these lower boards are E & F buffer boards , but I dont fully understand if this is what's at fault. Would simply replacing these clear the fault? If so, how do I go about it as I can't find any info on this on the web.
Any Help Greatfully Recieved!
