I picked this one up a few days ago. It had sound but no backlight (not even a flash). Putting my brightest flashlight on the screen showed an image. I thought this would be an easy deal. The inverter board that's in the tv is a samsung LJ97-02098A.
Now i have a cracked screen 40" proscan in my basement with a LJ97-02098B. Shop Jimmy shows these 2 inverter boards to be compatible substitutes. I tested the proscan a month ago when i got by letting it run for several hours non stop and it worked perfectly. So i pulled the inverter and swapped them out. The tv fired up backlights and all. I thought done....Wrong
When the tv is cold (off for several hours) The tv will turn on for about 3 minutes. But after that 3 minutes its on for 10 seconds then fully power off then turn back on. It keeps recycling until i hit the power button. If i unplug the inverter board the tv will stay on. There is still an image so the rest of the tv is working.
The inverter has a 3-4 wire plug that goes to the tcon. Could an arcing bulb cause the tcon to tell the main board to shut down or do you think its a heat issue. I know this inverter is good but i can always put it back in the proscan and see if it's still working correctly.
The panel is a LTA400HF02. I got the datasheet but i don't know if it has circuit protection built in. Just wondering which direction i should go with this.
