RCA LED46C45RQ,Sound but no Back lights
    Re: RCA LED46C45RQ,Sound but no Back lights
    With tester all lights lite at same brightness . when hooked up to power board lights don't come on
    voltage drops at connector
      If you have voltage at the connector you should have at least a flash of the led's
        Yes 1 flash then nothing
          did you check the leds individually? might give a clue.
            no
              Already put it back together
                thinking most of the time, that one flash means bad backlight led/s or poor backlight connection.
                  Don't know how to put more power to them other the tester that will tell
                    when testing with backlight tester, did you test thru the backlight cable going to the backlights or right on the strips, meaning did you verify continuity of the cable?
                      connector
                        Originally posted by tennno` View Post
                        Don't see any I got a different board today its doing the same thing joints on this board looks good
                        You had 0v at led connector with old board and now you have voltage at led connector with new board. Correct? And now you get a flash of backlights?
                          Yes but voltage drops off
                            Ok then you need to do what was suggested in post 40.
                              Reopened it and tested each led found 1 bad (dead)trying to locate a new strip
                              IC-A-KJAB46D444 (8 leds on strip)
                              flashes to fast to tell if brightness is different
                                https://www.youtube.com/watch?v=Y2Tv...ck%27sTVRepair
                                  Thanks All you guys for your help .I'll get back after I get different back lights and let you know.
