Hello there.
I have a Phillips with de attached COF cable (the glue let it go) that had lines on its display.
After I found out that the COF cable is dangling from the LCD panel, I looked up online if I can fix it without a bonding machine.
After tinning the COF cable and the PCB contacts I proceded to solder them together.
It was very tedious but using my tweezers, my phone as microscope and a shitton of agility I managed to bond them with my soldering station.
Now, with the COF cable reattached the lines are gone, but the screen is black, only the backlight is working and if I remove the COF cable with my hot air station the display shows purple and white, vertical bars with a black bar in the middle(where the COF is deattached).
I can upload pictures and even videos of the tinning of the contacts and of the reattached COF too if you wish.
What should I do now, guys?
