Hi, this Samsung 32" TV keeps dropping out from the signal. Message that appears on screen is to check connector, co-ax cable, etc. I know the aerial & digi receiving equipment works fine as two other TVs we have work perfectly on the same gear.
I did notice that the signal input connection is not very tight & using an alternative HDMI input doesn't respond.
Just wondered if there were known problem areas before I take the back off & go poking about.
