Sound output up a pitch on HP 6530b
    Hello all. I hope someone can shed some light on my issue. I have a rather old HP 6530b, which has suddenly begun to play audio at a higher pitch. I am sure this is a hardware issue as it had this characteristic with Windows 10 and the same when I changed over to Ubuntu. I have done the normal things, removing the RAM and re-seating, checking the fan is clean etc. I even reset the BIOS but nothing has worked. I should point out that when this happens, I generally lose my webcam and use of the usb's, which makes me think this is an internal power issue. I not brilliantly technical so your ideas would be most welcome. The machine is running an Intel 2 Duo CPU P8600 2.4Ghz. Thank you.
