Bush DLED48287HDCNTDFVPY Standby LED Blinking Constantly
    Re: Bush DLED48287HDCNTDFVPY Standby LED Blinking Constantly
    Nice work, glad the software could be found, there's SOO many tvs in the landfill because whoever put them on the market don't support them, even the so called name brands rush to take the firmware off their sites just as soon as they can, it's a damn shame.
      Originally posted by BL4K3Y View Post
      I tried again using this image and it worked!
      I spoke to Bush technical support earlier who agreed to send me the firmware files, but it looks like I won't be needing them.
      Thank you all very much for your help.
      If you can type MENU and 4725 and put the picture with the service menu.
        Is there something specific you are looking for on the service menu?
        I tested the TV again this morning and while everything appears to be working fine, I can't seem to find any HD channels after automatic channel tuning, but SD channels are working fine.
        I have tried to factory reset the TV from the menu, but I still can't find any HD channels.
        Is there anything I can check to resolve this?
        Thanks.
          Save the profile from the TV to a stick and post it here. It can be modified and solved.
            Can you explain how I do this please?
            I have gone through the service menu and I can't see any option that resembles what you are asking.
            Thanks.
              1. Format a stick (max. 4G) with FAT32
              2. Put an empty folder on the stick that you call downloadprofile.mb211
              3. Turn on the TV
              4. Insert the stick into usb. If you ask to open it, press NO
              5. Type MENU and 4725
              6. Go down to USB operations
              7. Type OK and wait a few seconds
              8. Back to exit the menu
              9. Turn off the TV and wait until the stb LED stops flashing
              10 Remove the TV stick. On it are the saved profile files from the TV
              11. Post them here to see if they can be modified for HD channels.
                3. Turn on the TV
                I followed the instructions above to obtain the necessary file(s) and I have attached a .zip file.
                Thanks.
                  I don't see anything suspicious in profiles. Everything seems right. Try scanning channels to select another country (eg Germany)
