TH-P50G15A - 6 Blinks- Bad TNPA4782
    Re: TH-P50G15A - 6 Blinks- Bad TNPA4782
    Which buffer ICs failed? tried removing a few failed ones and see if it will fire up with a pic?
      Don't have the gear. brought everything except the kitchen sink and the acetone
      Not worth the
      All connectors on the SD. 8 ICs on these too.
        I thought I also had this but nope. Found two resistors R521 and R522 open circuit near IC521. I initially had IC521 shorted which was replaced. replaced the resistors but still getting a short flash and then 6 blinks.
          Can you put a summary list of what you've replaced?
          Did you check those 2 diodes (marked 88) that I just had shorted ?
            Buffers are in. (thanks for Overnight express) Perfect,Perfect Perfect. Fantastic image and SC is now silent with a load .
            10500 Hrs
            Now have another TNPA4782 to repair. A lot learnt here as far as what parts you can get away with , with some lateral thinking and cross relating knowledge of the 5081 boards.
              Everything I found shorted so far:
              Q441 - 45G127 replaced with a 45G128
              IC521 - replaced with the 1737
              Q551
              Q661 - RJP6065 replaced with RJP63F3
              Q601 - RJP6026
              Q701
              Q702
              IC773
              D608
              D618
              R521
              R522
              I also checked all the parts that you had shorted or suspect and none seemed shorted, but I replaced some of them just in case.
                Just having a look at this spare dead 4782AF, straight away I see D618 is burnt. I'm starting to think i missed this as it's in the shadows of the heatsink .
                What's unusual is this too being revision AF , however it has a Vset cct.n So i have one which has and another not both AF. This board does look a little older so maybe mine was the last of a production change. Both TVs are P50G15A
                  Mine is the AB model, I got from a TCP50S1. I did the initial replacing parts and heard a pop and burnt smell which turned out to be D618, and also leading to D608 blowing ,Realizing I missed IC521 and Q551. after replacing everything again, 7 blinks turned to 6 blinks.
                  If the SC is repaired and with SC50 jumpered and SC plugged in, the set should stay on solid and no blinks correct?
                    Q551
                    Q601 - RJP6026
                    Q701
                    Q702
                    IC773
                    D608
                    D618
                    R521
                    R522
                    Does not seem quite fair does it.
                    I don't see and 2sk3018 or 78L05 regs replaced
                    have you tripled checked all smd diodes(large ones) and if 45G127 failed is the didoe in front of that ok and the 2 TO220 diode packs next to it?
                      yep and i strongly recommend you test it that way until it does becasue I'm convinced I killed my buffer boards.
                        Have you rechecked the buffers yet? I'd check Vfo at the connector to Vfg resistance
                          So far I also replaced Q818 2sk3018 and only IC771 78L05, IC724 and IC725 seem good. I checked about every large smd diode I can find and nothing seem shorted. Q441 was 45G127 (the one on the right heatsink). that one didn't have a diode in front of it. measuring the TO-220 diodes I'm getting 0.287 and OL.
                            Ok, well i'm only just starting on this but is your Q451 shorted G-E ? I'm finding you have to be 100% thorough nearly skipped over that one.
                            For transistors so far, Q661,601,441,451,D618,
                            Also, can you look at R869, R613 47K near D618. 613 is burnt and I can't get a stable reading suggesting these may have an issue but have not looked at the schematic yet
                              yep got mixed up with other 45g127, both mine are dead
                                my Q451 measures 0.674 and OL on G-E on diode mode. both my R869 and R613 slowly raises in resistance until around 42.8k ohms.
                                  Q701,702,818 no shorts but I'm replacing .
                                  I'm getting similar on those resistors. I may remove from cct and check since 1 is burnt at the solder.
                                  Well with mine at this stage I'm thinking
                                  Q601,661,441,451, 701,702,818,551
                                  D618,
                                  IC771,773,464,465(all of the Vcc lines are tied so I do not trust these inverters)
                                  IC521
                                    Pins 3-5 resistance on any of these IC773,464,465. What resistance do you have?
                                      With that zener D608 what do you get in diode mode both directions and what resistance both directions?
                                        Forgot to mention I also replaced IC773, 464, and 465 to be safe. For D806 i have 0.758 and OL in diode mode, 9.75k resistance in both directions
                                          interesting, I may have an issue there. i get the resistance but in diode 1.69 and 1.67. Do you remember waht yours was reading before you replaced it?
