I am working on MacBook 12" A1534 2017 820-00687-B assuming that the logic board is same as 820-00244-B. It was not powering on. I did a ultra sonic cleaning of the motherboard since I saw some traces of liquid spill. Tested out of the casing, all worked fine & display was working 100% well. When I installed it again, no display. So I again was removing the logic board & while removing the keyboard connector I saw little smoke off the connector. I started to check the voltages again. 3.3volts is perfect but 5 volts rail fluctuates on & off on coil L7670 (PP5V_S4)., 5V come & goes again. I did not find any short to ground on this rail. Any tips or guidance will really be appreciated. Thanks in advance.
Re: MacBook 12" A1534 2017 820-00687-B
Ok 'mon2"., on the EN1 pin of U7650 (PM_SLP_S5_L) the voltage toggles on & off, even on pin 7 & 8 same thing voltage toggles.. But EN2 (S5_PWR_EN) pin 21, here the voltage is constant 3volts, this is why I am getting the 3.3v perfectly. Next to check I think "PM_SLP_S5_L" from where it genereating or some rail. Please inform me.. Thanks
The CPU may be defective as reported by more seasoned techs on this forum but hate to believe it. It is a show stopper of an issue if true.
Our fancy BGA rework station should land next week and we are looking forward to complex repairs like CPU rework / reflowing. Has multiple HD vision cameras to perfectly align the balls once we clean the drop site.
2) What is the voltage on PM_SLP_S5_L ? nearly 2.9 & then drops
What is the voltage reading once this rail settles ?
