I got an old desktop case with an Intel D865GLC in it.
The main aspect that interests me is that it's new enough to have SATA ports and dual-channel RAM, but old enough to use leaded solder.
But there's a catch.
12V input is 4 x 1200uF Chemi-con KZEs. Vcore output is 7 x 680uF 2.5V Chemi-con PSAs and 3 x 820uF 6.3V (20mm tall) Nichicon HNs, which have blown their tops.
(7 x 680) + (3 x 820) = 7220uF total
10 x 680 (if they only used the 680uF PSAs) = 6800uF total
A big fat 6% difference. Why did they do this???
Those aren't the only HNs, by the way. I found two of the same HNs (blown, again) near the RAM slots.
I take it that they are for the RAM, after seeing two MOSFETs and a ferrite coil near one.
I remember seeing a similar board where the two caps near the RAM were 560uF 6.3V (23mm tall ) Rubycon MCZs. So I should be able to use 560uF 4V polys there?
I don't see any other defective Nichicons on the board. Though there are 85°C general purpose caps, which have been known to fail in the past. None of those are bulging though.
Intel
Intel
