I wonder how many people are in the same boat...
I have a pile of vacuum tubes I've collected over the years. Now the question is: which ones should be disposed of, if you don't have access to a tube tester?
I had swapped a tube into my AR-3 and noticed that sometimes the audio would cut out. Rapidly turning the radio off and on through the control knob "fixes" it, but pulling the plug and replugging rapidly does not.
I randomly swapped in another IF amplifier tube, and it seemed to have "fixed" it, suspecting the tube that I took out may be weak and perhaps should be binned. It's the 12BA6.
I wish the pinouts of tubes were consistent! I suppose luckily most 7-pin tubes have pins 3 and 4 as the heater, though cathode, plate, grids can be pretty much anything...
