Need UEFI Password Removed from my Surface Pro 5 BIOS DUMP
    Re: Need UEFI Password Removed from my Surface Pro 5 BIOS DUMP
    Originally posted by casol View Post
    Please help to remove the UEFI password.
    try..
      Surface 1796 Password Remove
      i download 2 , 3 different bios with other bios when press bios buttons its restart . this is his original bios please remove this password so i can install new windows. thanks in advance
        Re: Surface 1796 Password Remove
        try..
          thank you very much
            This one only removes password, leaves everything else unchanged.
              touchscreen not working even i change new screen still touch not working.
              before open the surface its working good.
                can you please teach me how to find password section in bios with HxD editor
                  With my file the touchscreen is working?
                  Compare your and my file, there is only one difference. It is always before the keyword AWord.
                    Guys ... My Surface Pro 5 Model 1796 was locked by BitLocker suddenly and I did not know the key and after many tries it was locked by uefi system password ... Can someone help me PLEASE here because Microsoft Did not help as usual by calling , chatting and even following their instructions ☹️
                      post the backup of the bios
                        Need some help on removing password from BIOS dump Surface Pro 5
                          try..
                            Originally posted by peste View Post
                            try..
                            hi friend, thanks for the file, but after installing the machine does not turn on. see
                              try this..
                                try this..
                                Not work
                                  Microsoft Surface Pro 5 1796
                                  Hello All,
                                  I'd like to know what tool, if any exit, that can be used to remove the UEFI password on my Microsoft Surface Pro 5 1796.
                                  I'm also attaching the Lock BIN file if anyone could help unlocking it that would be great.
                                  thanks for your help.
                                    Re: Microsoft Surface Pro 5 1796
                                    Originally posted by Korreia View Post
                                    Hello All,
                                    Try
                                      Originally posted by onizzbox View Post
                                      Try
                                      Thanks, but no go. The windows logo appear, then the surface shutdown.
                                        @Korreia
                                        Try
                                          Re: Surface Pro 5 bios dump
                                          Will these bios dumps fix the problem with touch firmware not updating? Or is it in a separate chip?
                                          I have tried changing the chip with a new one but the problem still remains
                                          I get the 0xc000002D error when windows reboots.
                                          Can anyone help? As even though I’ve changed the chip my serial number is still the same… wierd. Unless there is a second bios chip that is causing my issue.
