nvidia Geforce 9800 gt doesnt work
    hi guys i have a nvidia Geforce 9800 gt , when i press power button video card doesnt work, i mean fan doesnt spin, nothing happen, no video...can someone be kind of helping me fix these card...i already did a reflow nothing happen...where can i measure to know the problem..thanks....power supply atx is working good, the problem is on the video card..
    Re: nvidia Geforce 9800 gt doesnt work
    Your re-flow wasn't hot enough...
    If it was, that brown electrolytic capacitor in the bottom right corner would have bulged (That is almost certainly a Chemi-Con KZG series, which should be replaced).
    If you MUST use this card and are adamant about fixing it, then I suggest trying to re-flow it again, but this time squirt some liquid flux under the GPU BGA before you do, desolder that electrolytic cap, and re-flow it at the proper temperatures, following proper procedure.
      thanks friend, proper temperature would be 200 C would be ok, what do you think??
        385f or 196 Celsius about 6-8 minutes. 8800 ultra works fine now, I put it to oven 200 C
        about 7-8 min.
        Sorry for my bad english.
          The fan not spinning would suggest the card or fan (or both) are not getting any power. Reflowing won't fix that.
            No, proper temperature would be 225-235C. Ideally, when the temperature of the video card reaches 225-235C, it should stay like that for no more than 10-20 seconds. Then you turn the oven off and open the door *a little bit* to let out the heat and cool the card slowly.
            Lead-free solder melts at 217 Celsius, so you need at least that much for a proper reflow.
            Your 8800 Ultra likely got fixed because ovens are not 100% accurate with their temperature - they can over- and/or under-shoot by 5-15C.
