I have a tv with an 18N50 that blew. I have access to a 24N50. Could I use the 24N50 instead? The characteristics look the same but just the 24 amp drain current and the rds is is a little lower.
18n50 or 24N50
Re: 18n50 or 24N50
Originally posted by dcapper View PostI have a tv with an 18N50 that blew. I have access to a 24N50. Could I use the 24N50 instead? The characteristics look the same but just the 24 amp drain current and the rds is is a little lower.
That being said, it's HIGHLY unlikely that the difference between two like parts from the same series would be a problem, you could probably put two or more in parallel and still not have any problem.
