Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 01-05-2015, 04:23 PM   #1
Ltank
City & State: Florien, La
My Country: USA
I'm a: Professional Tech
Default LG TV Main Board Main CPU 42PT350
Last week we had bad weather and I have had 4 LG TVs come into shop. I replaced two main boards. It seems LG main cpu are very sensitive. I cant find schematics for many of the boards to find out the actual part number off the chips without removing the heatsink. Does any one know a source for the main IC chips used on LG TVs ? Is there a list some where that tells you what TV used what main IC ? Has anone sucessfully removed and install new ICs?
It seems a waste because the main CPU fails and the rest of the board seems good. The main ICs temp when failed all are in excess temp of 155 F.
IC1 has failed on EBT61712701 main board.
Ltank is offline   Reply With Quote
Old 01-05-2015, 04:55 PM   #2
Ltank
My Country: USA
Default Re: LG TV Main Board Main CPU 42PT350
Looking at the under side of the board they all have alot of SMD that would be affected by heat in the removal side if the bottom heater got too hot and the all the LG main cpu chips have all the pins under the IC making it guess work if all is properly aligned. I guess it either send it out to ModusLink or buy a board. Have any of you all have any luck with it?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2021
Powered by vBulletin ®
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
