Dell 7110 No display
    I have get Faulty dell 7110 motherboard with 2 beeps ,No display Issue
    i done both bios twice(ec and Main), Almost except +Vcc_gfx_core all voltages are ALRIGHT
    it takes 700 ma CURRENT
    DRMRST VOLTAGE IS OK
    pltrst ok
    hwpg ok
    1.5 and 3v run ok
    vcc core 1.15 ok
    vtt .77v ok
    Ram 1.80V ok
    25 mhz pch crytal waves (input/output)ok
    32 khz crytal ok
    no changes in amps while inserting RAM or without RAM
    Re: Dell 7110 No display
    If you study the diagram, you can make UMA by removing the VGA coil and shifting the resistance R243. Worth to try
    I'm not happy to be so strong. because it's not humanly
      Sametbey, the board is already UMA , so doesnt need
        this is the board pics
          Ram 1.8V -> is this a typo? Board is DDR3, should be 1.5V
            sorry sndestory , yes ram 1.5 v
              Does it have an external VGA output? Does the beep give an error code? Bios and processor can start. Finally you can try PCH chip reball.
                No External Output , 2 beep at start up( may be indicating RAM) , Checked with different ram, same result , On Ram slot pin no 199 - 3.3V Run Ok, pin 30- DRMRST -1.64V, Pin 203,204DDR VTT -.76V ok, Pin 1 VREF -.88V ok, but i notice that at the powering on the bios data is appear only for less than a second which is abnormal
                  try another processor.
                    checked with different processor as well , same result
                      Thanks guys finally get result and motherboard is alright , works fine
