Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > General Electronics Technical Discussion
Thread Tools Display Modes
Old 02-20-2021, 09:42 AM   #1
Bibdid
City & State: Leicester/Sheffield
My Country: UK
I'm a: Knowledge Seeker
Default Help substituting avalanche diode
repairs on an old CRT tv from the 80s that blew a flyback have led me to this diode which is reading near 0 in both directions. The diode is marked as an R2KY avalanche diode but is no longer manufactured.
I am fairly new to the world of electronics, could anyone help me source a suitable modern-day equivalent diode?
The datasheet of the diode can be found from
https://datasheetspdf.com/pdf/220430...ctorInc/R2KY/1
many thanks : )
Bibdid is offline   Reply With Quote
Old 02-20-2021, 12:19 PM   #2
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
I'm a: Professional Tech
Default Re: Help substituting avalanche diode
do you have a schematic to show where it was used?
stj is offline   Reply With Quote
Old 02-20-2021, 12:32 PM   #3
R_J
City & State: ☻
My Country: Canada
You can get one from here: https://www.ebay.co.uk/itm/R2KY-ZENE...-/192164981448
R_J is offline   Reply With Quote
Old 02-20-2021, 02:27 PM   #4
stj
stj's Avatar
NIKKO??? good luck.
that guy is down the road - he is hardly open and often exagerates stock.
but you may get lucky.
Old 02-20-2021, 06:12 PM   #5
Bibdid
My Country: UK
Quote:
unfortunately not. The tv is a Mitsubishi ct 2043B although it seems to be really obscure.
The diode is connected to a voltage regulator. I will have a look at making a schematic in the next few days : )
Old 02-20-2021, 06:15 PM   #6
Bibdid
My Country: UK
Quote:
Originally Posted by R_J View Post
Thanks, although I am a little worried that he states the part is 160v 1a as I'm sure the part should be 120v 2A?
I may give it a go though.
Old 02-20-2021, 06:23 PM   #7
petehall347
City & State: worcester
My Country: United Kingdom
what is the board number ? will be something like vestel------- or maybe Haier -----
there is a schematic but asks to sign up . http://freebodydiagram.archivioprimo...our-television
petehall347 is offline   Reply With Quote
Old 02-20-2021, 06:39 PM   #8
R_J
City & State: ☻
My Country: Canada
I believe it is just for over voltage protection on the +112 volt line to the horz. output section. I would replace the low voltage/capacity electrolytics in the primary, If they are bad the power supply might not regulate properly, it could also be bad caps on that B+ 112v line, If the caps go open the voltage can go up. You should be able to use the NTE570
Check the schematic for the CT-2153
Old 02-25-2021, 08:21 AM   #9
Bibdid
My Country: UK
That looks promising but the site seems to be very shady. Relinks me to scam sites.
I have attached some board model/serial numbers although it seems very obscure.
Old 02-25-2021, 08:38 AM   #10
Bibdid
My Country: UK
Thanks for the help. I measured the capacitance and esr of a few capacitors around that area and they are way out of spec. Is it possible that these caps took out the flyback? I know this tv has had a very hard life and the flyback exploded somewhat violently, with resin being thrown out a fair distance onto the board.
As for the schematic, is there any reason you recommend the CT-2153 over others, just out of curiosity?
Old 02-25-2021, 08:40 AM   #11
petehall347
. cant make sense out of the board numbers yet .. maybe there are more numbers or a sticker
Old 02-25-2021, 08:52 AM   #12
petehall347
this looks like it ...
https://elektrotanya.com/hitachi_ct2.../download.html
Old 02-25-2021, 12:06 PM   #13
R_J
City & State: ☻
My Country: Canada
It is possible that the power supply started to output a higher voltage causing the flyback to operate at a higher voltage and break down, but it could be the flyback was just at its end of life. I picked that schematic because I could not find the actual one for your tv so I found a Mitsubishi tv that had a similar circuit.
The Hitachi chassis is totally different
Old 02-25-2021, 01:09 PM   #14
stj
stj's Avatar
not hard to find.
it's D907
Old 02-26-2021, 12:08 AM   #15
redwire
City & State: Alberta
My Country: Canada
I would use P5KE120A TVS diode as a replacement.
redwire is offline   Reply With Quote
Old 02-26-2021, 09:40 PM   #16
sam_sam_sam
City & State: Sunny Jacksonville FL
My Country: USA
Line Voltage: 120 Volts 60 HZ
Is there anything special about this type diode
__________________
9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Old 02-26-2021, 11:03 PM   #17
redwire
My Country: Canada
It's got a misleading name "avalanche diode" and nominal 120V (130-155V) rating. So it's a zener (=avalanche mode) but the wide range of reverse voltage spec. and high surge capability 2A 100usec mean it's really a TVS diode.
In the TV circuit, I can't find the schematic again but it seems to be an overvoltage clamp for when the power supply puts out too much voltage.
If the STR fails or something else happens the rail can go too high and the TVS diode clams to protect something but it will cook and short if that stays true for a long time. I see main power like 115VDC go up too high due to a bad regulator and it damages other parts, flyback too if the x-ray protection does not trip.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2021
Powered by vBulletin ®
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
