Hello, I am new in this forum. I have a sony laptop whose motherboard is mbx -250 Z40HR MB S0203-2 and it is a little different from the one offered here. For example, the bat1 connector is 7 pins and the offered one is 10 pins, the PU4004 is 20 pins and the one of its forum is 8 pins, in short it changes a bit. The fault is a short circuit in the DCBATOUT that does not allow any voltage only the 19 V input and of course there is no 5.5 V, 3.3 V and it does not light any LEDs. I would appreciate your help and it is possible to supply the exact diagram. Cheers
Sony vaio MBX-250 Schematic
Re: No power, Sony vaio MBX-250
I attach the correct diagram. CheersLast edited by SMDFlea; 12-04-2020, 03:23 PM.
Re: Sony vaio MBX-250 Schematic
Thanks for the schematic, I have this motherboard and this is the schematic that it works, and not the other in the forum, that although similar, it doesn't have the same components.
I have the same problem but I do have 3.3v and 5v.
Did you resolve it, you might be able to give me an indication. Cheers.
