13 pin connector ALL VOLTS PRESENT WHEN PSON CONNECTED TO 5VSB
1 12v
2 12v
3 GND
4 GND
5 GND
6 5V
7 5V
8 5VSB
9 PSON
10 5V
11 5V
12 GND
13 GND
6 PIN CONNECTOR ALL VOLTS PRESENT WHEN BK CONNECTED TO 5V
1 GND
2 GND
3 ADJ
4 BK
5 12V
6 12V
when tricked with pson and bk connected to 5v sources, backlights come on and stay on.
they seem a bit dim though. maybe too much sunlight in the room?
LED CONNECTORS:
2 STRINGS
WITH LED TESTER, BOTH STRINGS READ 26V
but with psu tricked, and measuring the voltage going to the strings,
one string reads 26v and the other reads 56v??
btn board
has 3.5v on both signal wires at rest.
pushing buttons changes voltage, specifically it drops the voltage a certain amount on one of the wires
pushing power button does not change the voltage on either wire.
IR/LED board
has 5v going to it
but only 1.6v to the LED
LED lights up but seems dim. i could be wrong. maybe thats normal. i havent seen many westinghouse tvs. this is maybe the 3rd one ive ever worked on.
when the ir/led board is disconnected the blue wire coming from the mainboard that goes directly from the connector to the LED on the ir/led board reads at 5v.
LED does not respond (blink, dim, brighten) to any to any button presses.
i programmed a universal remote to both codes it listed for westinghouse, and neither of them had any effect on the tv.
possible LED/IR/BTN board failure? easy fix??
i can find the Mainboard on ebay but not the button board or ir/led board
how can i simulate a power button press to the mainboard with all boards connected (or just the Button board and ir/led disconnected)?
ive tried jumpering the pson to the 5vsb with the mainboard attatched but it had no effect.
i tried all combinations of boards plugged in or not.
having a hard time deciding if its the mainboard or the BTN or LED/IR ...
i really think that if all the other buttons change the voltage on the pins of the button board, but the power button does not, this is definitely a problem with the button board. am i right about that?
help me out if you can. i realize westinghouse is not a very popular brand, but they make a decent tv. better than emerson/funai anyway
1 12v
2 12v
3 GND
4 GND
5 GND
6 5V
7 5V
8 5VSB
9 PSON
10 5V
11 5V
12 GND
13 GND
1 GND
2 GND
3 ADJ
4 BK
5 12V
6 12V
LED CONNECTORS:
2 STRINGS
btn board
IR/LED board
has 5v going to it
