Eeprom dump thread!
This is a sticky topic.
    Re: Eeprom dump thread!
    Someone send me the file
    here is:
    Blaupunkt 40/148i-GB-5B-FHBKUP-EU
    Chassis: TP.MSD309.BP85
    Model: B40A148TCFHD
    Product code: BA40I148BFBKPE061
    Label on LED screen:
    Model: 0040CA001
    LSC400HM06
    Note: The rom from previous post (133i) works after a day of test
      Blaupunkt
        Dump of Flash chip U202
        Vizio P502UI-B1E 756TXECB0TK004
          Westinghouse DW46F1Y1 IC_GD25Q16B
            Westinghouse DW50F1Y1-TW-74301-A050A-31H0011 IC_MX25L1606E
              emerson lf501em4 virgin dump
                Does anyone have a a file for a :
                EGL ETV32DVDH
                Mainboard :HK-T.RT2957P63
                Thanks in advance
                  EGL ETV32DVDH
                  Thanks in advance
                  Try this one. The panel is different, but it may work.
                  (Main Board): MAIN HK-T.RT2957P63
                  eeprom 25Q64
                  V420HJ2-P01-C4-12V
                    eeprom 25Q64
                    V420HJ2-P01-C4-12V
                    Hi AGRO many thanks for the file - do you or does anyone know if I need to programme this in circuit or does it need removed flashed and then replaced??
                    TIA
                      TIA
                      You should remove it first
                        Hi, guys how are you?
                        Here I have Bush TV. Model: LED19134HDDVD
                        Mainboard: HannStar 17MB82-2
                        The problem is 'power light flashes 5 times'. I think that the problem is in EEPROM.
                        Would you guys help me with dump file for this model, please?
                        Thank you in advance.
                          Thanks Ducky - Going to give this a go over the weekend.
                            Sorted with flash for Technika19 (both bin files added)
                              T-con board
                              EEPROM 24C128
                              RUNTK5489TP0116FVZA ( Sharp LC-60LE644U )
                              RUNTK5489TP0116FV (Vizio E60-C3)
                              Mirror Switch - see picture.
                                please dump 17MB62-2.5 PAINEL M215HGE
                                LCD MITSAI 22VLM12
                                  Originally posted by nourchab View Post
                                  Main Board: TP.MS338.PB801
                                  RĂ©solution : 1920x1080
                                  FIRMWARE DOWNLOAD:
                                  https://goo.gl/XuMvu1
                                  part 4 not available......plzz provide one link file..
                                    Technika 32" Eeprom
                                    Hi Gents.
                                    Brand:- Technika
                                    Model 32/122J-GB-3B-HCU-UK
                                    Main A/V TP.MSD309.BP75
                                    Screen LC320DXN (SF) (R2)
                                    Need Eeprom Dump If Any Has It.
                                      TV SEIKI SE50FY10
                                      Board: CV3393BH-F
                                      CPU: MSD318LU
                                      Eeprom dump and service manual for the board
                                        Originally posted by DWdisplay View Post
                                        I am looking for Eeprom dump Supersonic models sc-1912, sc-2212 or any one with the board CV3393BL-C or similar in any brand
                                        take a look to my previous post.
                                          RCA TV (a lot of model uses that board, so check by board, not TV model)
                                          RCA LED32G30RQD
                                          RCA LED40G45RQ
                                          RCA LED42C45RQ
                                          RCA LED46C45RQ
                                          RCA LED48G45RQ
                                          RCA LED50B45RQ
                                          RCA LED52B45RQ
                                          RCA LED55C55R120Q
                                          RCA LED60B55R120Q
                                          EEPROM (firmware Dump)
                                          Service menu: menu+1+1+4+7
