Badcaps.net Forum
Go Back   Badcaps Forums > Motherboards with Bad Capacitors > Other Devices with Bad Capacitors
Thread Tools Display Modes
Old Yesterday, 11:46 PM   #61
Log_on_Bob
City & State: Fullerton
My Country: USA
I'm a: Knowledge Seeker
Default Re: Whirlpool Refrigerator LED lights flickering
Bluto
Exactly... I had to go but that was the next plan to test. Now, on the bench I did test Top light direct so 120v. tapped in 2 more lights in series. These lights say Non-dimming but they worked without any flicker. Voltage across either of those two bulbs was 53.9v so a bit less but close to what Ohms law says. That was as far as I got...
Still pretty bright, no where as bright as the single light but to my surprise, still a Daylight White. The single light is too bright to look at until it is put away fully installed in the holder, then it's fine. This should be just fine OK but what I don't know is will those two fail shortly being supplied half their rated voltage. I plan to test both ways as the diagram and all three with two in series. Since I now have 6 bulbs, if 2 burn out no biggie or if I want more light in the Freezer I can go with just the two and 120v in the freezer.
I sure didn't feel that more light is really needed low on the Refer side but we will see, I will put up some pics later.
Log_on_Bob is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
