LITEON PS1211 power supply
    hello. have this PS from cisco switch.
    it have V+/400V/, but dont have VCC, VG and VS. can someone lead me to repair?
    Re: LITEON PS1211 power supply
    Check R310, R318 and C306,You need at least +8 volts vcc for ic300 or you could have a faulty ic300
      Also check C308, the 10uF, 50V small electrolytic cap. If it's bad, IC300, the 3845B PWM IC, cannot start up. If it's bad, use a Nichicon PW, Nippon Chemi-Con LXZ, or Panasonic FC series part. C308 is stressed some.
      PeteS in CA
        hello.
        Thanks for advices.
        i have 8V on 7pin of IC300, but no voltage on any other pin
          IC300 pin 8 is zero volts? It's the 5V Reference for the IC. IC300 may be bad, or C301 may be bad. Do you have a really low resistance from IC300-8 to IC300-5?
          PeteS in CA
            8 volts is at the low end (cutoff) I believe it should have a bit more voltage to start up. I would think it should be at least 10 volts when first powerd on. I might also check D304, R311 and ZD301 That part of the circuit keeps the ic running
            I also think the ic300 could be bad
              now i have 2 of them in the same condition, but the second have 10V Vcc, Vref ok,
                what voltages must be on this chip so it must work?
                  If ypu have 0 volts on Vref, either the ic is defective or a component is shorted that is connected to pin 8. Did you check fet Q102, zd102,zd103 and R116? if R116 is open, q102 is bad. ZD103 needs to be checked out of circuit if R116 is good
                  Check R311, zd301 and d304 they supply the run voltage when the circuit is working.
                  Also check that D203 is not shorted on the +12VCS
                    the secondone is miraccly started to working. i measure ic300 and first not working have 0.7V Vref and VCC 8.5V
                    Second have VCC 10V and Vref 5V
                    interchanged ic300 but nothing changed so ic300 is good
                    resistance between gnd and VCC is on working board about 15kohm and not working 13kohm
                      If the second one had been not working and suddenly started, I'd look for bad solder joints on the primary side. That assumes that R310, R318, and C308 are good - if either resistor is open or C308 has gone high ESR the 3845B, IC300, will not start up.
                      PeteS in CA
                        do u think i can lower one of the feeding resistor to bring vcc higher?
                          i measure resistance to ground on all pins of ic300 and it is nearly identical
                            i mean compared to good one board
                            even IC051 and ic101 have same pin resistance to ground on bad and working board
                              i think that come caps is bad. can anyone lead me what caps to check?
                                now the revived PSU died again and i notice that VCC falls from 10 to 8.5 and Vref goes to 0.8V as the bad PSU. So i think that main problem is very low VCC to start ic.
                                what component can be behind that voltage lowering?
                                every component i measure was in tolerance
                                  Do you still have pfc boost voltage +V400 volts?
                                    where i can find "pfc boost voltage"?
                                    +V is 415V
                                      i try tip from youtube, where guy trying to find capacitor that were little bad with hot air
                                      so i heat some of them with hotair gun and u know what? when i heat one of them i have good output voltage :-)
                                      VCC also rise up to cca 10V
                                      it was C902 - 4,7uF so i check it and have this reading:
                                      4,4uF, ESR-2,3ohm, Vloss-1,3%
                                      i replace it and PSU now work
                                      as i see there are some same capacitors, so i replace them all
                                        IM REALLY GETTING SICK OF THIS SHIT
                                        replaced all small caps, but still after some time/hour or little more/ the PSU failed to start
                                        as i said earlier after little heat from hotair station/which was a tip from youtube for finding failing caps/ in one location the PSU start
                                        What can be bad?
