picked up this tv a while ago, had no power but audio, pulled power board from tv to take measurements and such, plugged in several times to check measurements and then all of a sudden something failed/shorted and and basically ruined board
So basically i found and ordered a replacement power board, got it but was so busy at work it was a month before i could try it and now it is too late to return it, basically on the new board i dont get any voltages on the test points where the main board feeds power to the other boards, also tried across main caps and power transistor, both still 0V, doesn't make sense to me as it looks the the board was refurbished and a few of the caps seem to be upgraded from the parts store i bought it off of, checked fuses on main board also, they tested good, ill post pics of the board, hopefully they are clear enough to see
