VeiwSonic VA912b
    VeiwSonic VA912b
    Flashing green light. No picture. All the caps were CapXon.
    The three bulging caps were 470uf 25v reading between 3 and 7 ohms esr. The big 100uf 400v cap had a slight bulge but was open.
    Cap list
    KF series: mfr spec qty
    470uf 25v 10mm x 16mm ripple=1200 imp= .076 5
    470uf 10v 8mm x 12mm ripple=580 imp= .25 1
    KM series:
    100uf 400v 18mm x 35.5mm ripple=550
    I replaced the KF series with Nichicon PW, same sizes and spec.
    The KM series I used a Nichicon PB that was 18mm x 40mm.
    There was a small cap that looked like a 22uf 25v that was covered in glue that I left in.
    Re: VeiwSonic VA912b
    Wow thats a beefy HV transformer.
    Does it have both inverter circuits in one package?
      Good observation.
      It seems the better or more efficiant the transformer the smaller the mosfets are.
      The last two inverter modules I bought yesterday have no discrete components and drive six lamps.
      https://cdn.badcaps-static.com/pdfs/...895fd1b84c.pdf
      These fail also, I have a collection of dead ones.
      Jim
        Hello ... I'm new to caps...
        Well I started wiring a junk va912b ....
        It does not look like the one above..
        with a power supply from a NEC LCD19WV power supply...
        YA it's a good one... I Found the problem with that one too late... ripped wire ... I'll make it fit..
        All I need to finish is the pin outs for CN1 Plug to power the main dvi/vga board.
        on the Viewsonic VA912b.
        I'm also gonna wire the board to the pc power supply.
