Laptop totally dead, where to start?
    Re: Laptop totally dead, where to start?
    Hi dj ricoh, long time.
    Sorry, I do not understand.
    Given the data as it is so far, where do I inject and which voltage?
    And what is a continuity test?
    New measurements on PU19< With PL6 still unsoldered
    Picture 1 with the standard values and picture 2 with the values after pressing on/off switch. Led from switch turns off after 3 seconds,but the voltage stays 30 seconds
      Originally posted by dj_ricoh View Post
      you got a short to ground.
      trace it. Continuity test
      a SVF15 and SVF14 one Hour both.
      found a short, injected voltage and found what was bad
      The continuity test I get now. Didn't know the English word.
      The other question is still there, but the question is in fact: Which Voltage?
      The +1_5VSUS looks to make the problem, or the DCBATOUT too.
      So, what is the next step.
        Now when I connect the power, PU13 gets very hot, (PL6 still desoldered).
        I see on pin 8,9, 10 = 19,19 V and pin 10 is going to PL6 and then to the +1_5VSUS.
        This 19,9V can not be good there, where does it come from.
        I want to learn, can one of you Pro's pls help me out?
          pu19 pin 6 , what do you got ? and also pq70 pin 8
            1.5 volt are related with ram. remove ram slot and see if pc power and stay on.
              Thx Highpulse and Dellxps15,
              Sorry Guy's, regretfullyto I blew up PU13, when I took it off en put it back, now the board is completely dead. I have to check for a new PU13. Till then, I will proceed with the other thread in the meantime. Thanks
                What is the best way to remove a ram slot. (got me afraid)
                  just ram i mean memory module (sorry my bad english)
                    Pffffffeeeewww, that's a re-leave. Would be a big job.
                    With or without ram module no difference.
                      bicalov if you have a components in short , in this moment , its not the best moment to make test on the board , first replace pu13 since its 1.5vsus and 3.3valw is attached there , could take you to wrong ideas , tps51218 you can find them on recent board with pch or ddr3 , look carefully on board you might got there , you must get lucky in finding one
                        Thx, I will do that
                          any pads shorted to ground on PL6?
                            With one side desoldered, the side at PC152 is shorted to gnd.
                            Last edited by bicalov; 02-04-2016, 04:40 PM. Reason: was pc and not pr152, thx delxps15
                              maybe u mean pc152. desolder pl6. still pc152 shorted?
                              if yes remove pc138.
                              short gone?
                              if not remove pc14.
                              short gone?
                              if not remove pq44.
                              short gone?
                              if not remove pc190 pd16
                              going on.... for +1_5VSUS spot on mainboard and isolating that rail.
                                Tried everything but no luck. Took a long time to find components, could not find PC190. It can be located in the schematics where is is connected to, but not on the board.
                                I also have problem to locate the rest of the rail. sorry and thanks for your help
                                  Followed short to GPU with voltage injection.
                                  Now it stops, because I don't have the equipment to change it.
                                  Maybe the short is not in the GPU, but in the many capacitors. Regretfully this can't be checked, because there are no markings on the board and you need a boardview, which is not available.
                                  Thread can close now, thank you guys for the input
